![]() | Home > For Sale & Wanted > [For Sale] Remapped ecu's for sale |
Ragerover Member Since: 26 Dec 2013 Location: In a land far far away Posts: 145 ![]() ![]() |
Forgot to say there's a matching alarm module box for these too for £100
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
PM Sent 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
LandieG Member Since: 13 Mar 2013 Location: nr Caerphilly Posts: 91 ![]() |
How much for standard 07 ecu px? Is 2nd ecu still up 4 grabs? |
Pm sent
Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233 ![]() ![]() ![]() |
120 what, not MPH !
CTPS 'Colon twitches per second' at that speed in a vehicle with the aerodynamics of a house brick. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Off the top of Beachy Head !!!!
Considering Twisted's LS3 Defender only did 129 mph in LRO, not bad for a remap. I think Mr Bell may have some serious competition ! |
In mitigation 'Mr Bell' is in the affordability bracket of many.....Twisted isn't. For example a quick look at their site and a KBX Premium Grill is nearly £90 more than the same item from Paddocks, stainless lamp bezels £36 when from Mobilecentre they are £18:49, the list goes on? Depends how deep your pockets are and how far (or should that read fast) you want to go and if you want value for money or just find the nearest drain and feed your 'hard earnt' into it!!!!!
![]() Treat every day as if it is your last....one day you will be right!! |
Will only work on early TD5's pm me your ECU number and I'll let you know |
Yep. And not too unstable... Until you try and break sharply |
Not just a remap Inter cooler , hoist wound up to 26 psi, boost box, filter, airbox mod and straight through pipe Oh and for added acceleration running a nitrous kit.. No difference top end but gets there quicker |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
if its td5 teritory from irb it will be mr bells maps anyway
![]() 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Welly911 Member Since: 14 Oct 2012 Location: Cheshire Posts: 70 ![]() ![]() |
Just wondering what the situation of both ECUs were? Are they still both for sale? If so can I contact you for more info. Cheers Mike
Mine's a 2006 TD5..... |
The milder one has gone
Pm me your number And ill ring you Obviously not in Dubai |
