![]() | Home > Technical > fuel pump ???????????? |
Simon,
I had a 3.9 V8 Disco and the fuel pump and sender unit was a single item. Not sure on the Range Rover set up. Mine packed up and there was an access panel underneath the rear loadspace where you could change it. I initially got a supposed 'reconditioned one' that ran really noisily and the sender unit didn't work, subsequently no fuel gauging! Best bet get a new one from Land Rover if it is the same combined pump/sender unit. Or try here: http://www.paddockspares.com/sp/cat/DEFEND...Pumps.html Or here: http://www.rimmerbros.co.uk/Item--i-GRID010439 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 17th May 2010 8:52pm. Edited 1 time in total |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 ![]() ![]() ![]() |
I have been told that an external pump wont pull the fuel from the tank is this true unles its lower than the tank
You could put it on the roof!
Ask anyone who's had a tank sucked flat ![]() |
I dont have a roof
Not 100% sure but each vehicle I have owned the fuel pump has been situated as near as damn it to the bottom level of the tank. It does go without saying that the pump in this position will not have to work quite so hard and there is little possibility of cavitation occurring in the pipes if the pump is being gravity fed too. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
