Home > Puma (Tdci) > A/C not blowing as it used to be
SkyFallSilver
Kuwait
Hello,
I have just set into 1 year of ownership, the weather is getting hotter over here and I recently noticed that the first fan speed isn't as strong as it used to be when the AC is on and not cooling as I was used to having(not blowing as strong as I used to experience it). Recently I am using second fan speed, in all situations its blowing cold but the force of air is not as strong.
Is it the A/C filter, I assume that because on a similar situation my G55 AMG the first fan speed and second didn't feel much different and the dealership all they did is replace the ac filter and it solved that issue (probably clogged/dust) given my location.
My defender blows cold air but the force of power is not as I am used to. The car has gas for the AC in it as its only 1 year old and I don't think I need to fill it up
Thoughts ? 2016 Defender 90 Adventure Edition
Post #324008 15th Apr 2014 11:26pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
No A/C filter in defenders … could be the heat exchanger itself that has clogged up or is icing up?
Annoyingly to get to the heat exchanger you have to remove the whole dashboard …
I would first look at the actual blower in the engine compartment. might have something (sand?) in there blocking the free airflow.
Since it is still under warranty, let the garage sort it out ...
Post #324017 16th Apr 2014 4:58am
SkyFallSilver
Kuwait
The car blows cold air but the power is not like before, the weather has changed recently towards 36 C but the a/c doesn't feel as strong as it is before.
I feel that the sound is different, my car is LHD and I listen to the blower under the right side dash sounds a bit different. 2016 Defender 90 Adventure Edition
Post #324078 16th Apr 2014 2:06pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
If this happens with or without A/C on then I would look at the heater air inlet duct. Could it be partially blocked. There is no heater circuit filter, but there are 2 water drains on the underside of the engine compartment ducts. The Defender A/C and heater system is not very sophisticated. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #324105 16th Apr 2014 7:16pm
WelshGas
Post #324106 16th Apr 2014 7:17pm
SkyFallSilver
Kuwait
I think it feels the same regardless if its on, I will double check tomorrow to be precise with my findings. 2016 Defender 90 Adventure Edition
Post #324143 16th Apr 2014 9:55pm
SkyFallSilver
Kuwait
Those stuff occurred after I installed the snorkel raised air intake, actually it was fine till I took it to the service centre and got it back where is the heater air inlet duct located ?
My car is a LHD, under the passenger side there is like a rectangle opening for A/C or heater perhaps, that sounds different when the fan is set to 1>2>3 on fan speed. 2016 Defender 90 Adventure Edition
Post #324153 16th Apr 2014 10:11pm
Rakthi
Just a guess ...
Have you set the fan on taking air from the outside or recycling the inside air? Makes a big difference in cooling and noise factor.
I live in the sub tropics here and I always have the fan set for recycling inside air. Makes for more noise but at least I get some cool air.
Could be that the blokes in the garage moved the lever, or that that lever is not completely engaged?
Otherwise the outside air intake for the fan is on top of the passenger wing. If you open the hood you can see the tubing running to the actual fan unit.
Post #324207 17th Apr 2014 2:55am
SkyFallSilver
Kuwait
re circulated air inside. i never moved the lever. 2016 Defender 90 Adventure Edition
Post #324217 17th Apr 2014 6:50am
SkyFallSilver
Kuwait
Booked an appointment for a checkup, however I took the car to a friend mechanic and told its cool but the blowing power is reduced.
I think it may have sucked some of the paper floor things they give back when you take your car out of service. 2016 Defender 90 Adventure Edition
Post #324300 17th Apr 2014 2:58pm
