Home > Td5 > Redline MTL 75w-80
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Redline MTL 75w-80
Has anyone used this as gearbox oil in their TD5s and if so is it any good?
Post #322704 9th Apr 2014 5:11pm
jimbob7
No, MTF 94 only,according to nearly everyone including Ashcrofts and Landrover.Some say ATF gives a smoother change but MTF gives better protection,you'll struggle to find anyone (sane,lol)who recommends 75w-80/90. Pov.spec,ftw. 2006, 110,TD5.
Post #322771 9th Apr 2014 8:53pm
Tommo
Thanks for reply Thumbs Up
Post #322779 9th Apr 2014 9:17pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
75w80 is used in diffs or transfer box on Td5 can,t remember which without checking handbook, deffo not main gearbox though. 2005 Td5 90 XS
Steve
Post #322782 9th Apr 2014 9:26pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Gearbox MTF94
Diffs EP90
T/box 75/90 It wasn't me!
Post #322794 9th Apr 2014 10:12pm
Tommo
Thanks for replies.
I have tried to find Texaco MTF94 but have been unsuccessful.
Smith and Allan have a MTF 94 which is about £20 for 5 litres...anyone used this?
Post #322807 10th Apr 2014 5:03am
jimbob7
I get mine from a Landrover dealer, R380's can get seriously upset with the wrong oil,why risk it?? Think about £8 a liter. A meter of plastic pipe from B&Q a smallish plastic funnel (couple of quid all in) you can fill the gearbox up from the back of the engine bay Thumbs Up . Pov.spec,ftw. 2006, 110,TD5.
Post #322812 10th Apr 2014 6:16am
Tommo
TBH I never thought about buying from LR direct as I thought that I could source elsewhere but that is sound advice JImbob7.
Post #322935 10th Apr 2014 4:36pm
Tommo
Have finally decided on the oils and service items for my td5.
engine oil- Castro magnatec 5w-30 a1 £44 (8 litres)
filters etc- Duckworth (LR) service kit £68
Main gearbox- LR mtf 94 £37.98 (5 litres)
Transfer gearbox- Castrol universal 75w-90 £29.96 (3 litres)
Axle- Castrol EPX 80w-90 £23.97 (3 litres)
approx. Total £204
compared to LR I think this is a good price and it uses recommended service items!!
Post #323154 11th Apr 2014 7:54pm
jimbob7
Ouch Shocked,but yeah, DIY every time Thumbs Up .
Don't forget to grease the prop shafts,I bought el'cheapo Silverline grease gun off Amazon, which fits on the nipples with a bit of wiggling (some don't). Pov.spec,ftw. 2006, 110,TD5.
Post #323179 11th Apr 2014 9:06pm
Tommo
I know what you mean about the nipples Wink , but have bought a flexible end to the grease gun which works a treat.
As for the cost, I was paying a fair bit more to keep the trooper serviced and it did not include all the gear oils!
Do the main gearbox, transfer box and axles need doing every year?
If no then there will be a saving next year on those items.
The other issue for me is that I will use recommended LR oils / filters etc which as I will service the defender myself will hopefully keep the value good as ill staple the receipts into the service book.
Post #323224 12th Apr 2014 6:57am
jimbob7
Yeah, only engine oil and spinner filter need changing every year,I could be wrong, but I think gearbox/t-box axle's, officially only need doing every 70k,i ain't lettin mine go that long without a change tho.
Be careful usin flexi-pipe on the grease gun,they're not rated to anywhere near the same pressure as the solid pipe and often split in use,usually coz the uj seals are bunged up wi cr*p and need plenty'o'pressure to clear it. Pov.spec,ftw. 2006, 110,TD5.
Post #323263 12th Apr 2014 9:32am
