Home > Puma (Tdci) > Yet more Trouble (Gear Box Related) |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
take it back and show them,they will have to sort it for you,or call LR customer services first 2.4 90 XS
15th May 2010 9:09am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
probably you are in the situation where you need a good LR mechanic. Perhaps they did not set up well the diff lock lever. Now about the GBox, have them to check the clutch plate.
Also, check on the number plate of the Gbox. Puma 110" SW ............................................................. Earth first. Other planets later |
15th May 2010 9:41am |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
...as well as complain til you're blue in the face. Then make sure you ring LR Cust Services and complain until you get at least £1000 in "good will" compensation to spend at your dealership and a few free services. It's what they're there for
15th May 2010 9:44am |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Hi i had a simler problem with mine.....New box was worse than the old with selecting ...took it back and they had another go perfect ...........Just take it back and get the head mechanic to sort it out NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
15th May 2010 10:31am |
