Home > In Car Electronics > What wire for spotlights |
4 x 55w will draw around 18 amps, so if you want them all on the same switch then your 32 amp wire will be plenty. If switched in two pairs then 2 x 16 amp cables will also be fine. Either way, 1 x 32 amp earth cable daisy chained to all four will reduce the number of individual cables needed to roof level. Darren
2nd Apr 2014 8:32pm |
I ran the power for my light bar from the battery box, inside convoluted trunking next to the main +ve feed then up behind the heater and out behind the back of the bonnet.
I plan to buy another windscreen "hinge thingy" and weld/bolt a tube that will go up as far as the rack and run the convoluted trunking / wires inside. Polevolt.co.uk sell some good quality twin cable by the metre, together with quality relays etc. |
3rd Apr 2014 6:20am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5857 |
Cheers chaps for the info. I was wondering about the voltage drop hence going for higher amp wire. 1999 Defender TD5 110
5th Apr 2014 11:49am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20477 |
The bigger the better. (with in reason) I'd recommend thin wall too, that way you get max conductor size with smaller OD.
Most new vehicles always run thin wall generally, type in thin wall on eBay and you'll usually find some. I normally use this place: http://www.ebay.co.uk/itm/12v-24v-AUTOMOTI...3a8a9bd3b8 http://stores.ebay.co.uk/Choice-Cables |
5th Apr 2014 12:46pm |
Cheers. C90. I have been using http://stores.ebay.co.uk/kojaycatvehiclewiring/ 1999 Defender TD5 110
5th Apr 2014 4:44pm |
2 core might be the neatest solution for more visible areas, it's what I've used.
5th Apr 2014 5:18pm |
That sounds like a good idea to me! I was going to use split tubing and single strands of wire for each connection 1999 Defender TD5 110
8th Apr 2014 12:05pm |
