Home > Maintenance & Modifications > Self-tapping screws or rivets?
Tillerman56
Netherlands 2002 Defender 90 Td5 HT Epsom Green
I am planning to fit a raised air intake. The upper part comes on the post of the windscreen. Some fiddley looking rivets came with the RAI.
I am in doubt if I should use these rivets (I'll have to buy a rivet gun then), or are self-tapping screws a better option? What are your thoughts?
Thanks
Tillerman.
Post #320987 2nd Apr 2014 9:13am
nakatanenga
Germany
The rivets have more strength as the screws and they are aluminium. So there will be no contact corrosion to your window frame.
We are manufacturing your RAI for over 15 years, using these rivets and never noticed any problem with it. WANTED:
SII or SIII in max 1.5k
Post #320989 2nd Apr 2014 9:18am
Tillerman56
OK, thanks. I'm out to buy a rivet gun then!
Tillerman.
Post #320990 2nd Apr 2014 9:23am
VeeTee
Netherlands
Use the rivnut. No need to buy a special tool, you can use a diy tool:
http://www.defender2.net/forum/topic8631.h...ivnut+tool
... Or PM me your location, I have a rivnut tool you can borrow. 😉 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #320991 2nd Apr 2014 9:28am
Rivet not RivNUT Thumbs Up
but still a nice guesture Thumbs Up
Post #320996 2nd Apr 2014 10:29am
nakatanenga
Germany
Rivnuts are available in aluminium, steel or stainless. Aluminium is good in contact corrosion, steel or stainless not. The next thing is that the weakening of the frame is higher, 4.8mm rivet is a 5mm hole. M6 rivnut is an 11mm hole. The frame is cast and not very meaty. WANTED:
Post #321003 2nd Apr 2014 10:56am
VeeTee
Netherlands
Aha, I read rivNUT, because mine (Mantec) came with rivnuts. Thumbs Up
@Tillerman: and I also have rivet tool you can borrow Laughing Cheers, Vincent
MySite
Post #321015 2nd Apr 2014 11:42am
Tillerman56
Very kind of you, VeeTee, but I found out there is a rivet gun in the family. So, that's solved. Thanks anyway!
Tillerman.
Post #321081 2nd Apr 2014 5:45pm
I'd stick with the rivets your motor your choice Thumbs Up
a great tool BTW for Rivnuts is the Pop PNT210 great bit of kit Thumbs Up
Post #321082 2nd Apr 2014 6:02pm
K9F
NEITHER!!!
Don't drill it at all would be my advice. Sikaflex it....I have. Thumbs Up
Old....
New...
No holes = No issues later. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #321197 3rd Apr 2014 8:03am
