Home > Puma (Tdci) > Gearbox oil on 2008
Ian Mac
2008 Defender 110 Puma 2.4 XS CSW Java Black
Gearbox oil on 2008
Evening
I serviced my car and done all the fluids. On draining the gear box the fluid was red like ATF fluid. The fluid was not that dirty but I am a little baffled why it's red unlik the golden castrol syntrans oil I just put back in
So do they do the correct grade in red or was it the wrong stuff. It does seam 100 times better to drive now
Thanks
Ian 2008 TDCI 110 XS
1985 90 300tdi. Gone
2005 RR vogue TD6. Gone
Post #320411 30th Mar 2014 10:27pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Sounds like it had the wrong oil in it. I put red ATF in my discovery auto gearbox, certainly not a manual. If it feels better you should be ok. 130 crew cab
98 V8 Disco
Post #320419 31st Mar 2014 12:20am
LR90XS2011
Just done my 2011 that was clean and red as well (only 11k miles) , I would not worry it is probably just the brand Land Rover use at the factory DEFENDER 90 TDCI XS,
Post #320423 31st Mar 2014 5:13am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I also had this and questioned the garage that had put it in and they confirmed it was the correct oil and they had questioned the supplier when it arrived as they thought it was incorrect. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #320510 31st Mar 2014 2:36pm
parktag
It used to be so simple changing oils but these days with the choices available you obviously can't judge by the colour any more. Smile 130 crew cab
98 V8 Disco
Post #320956 1st Apr 2014 9:57pm
