Home > Puma (Tdci) > Clutch 2nd type
MK
Clutch 2nd type
Apparently some Puma users had their 2nd generation-upgraded clutch also replaced. Would be healthy to know the technical reasons why this happened or what did the dealer say about it. Doubts arise if those 2nd clutches were really the new version. Puma 110" SW
Post #32095 13th May 2010 12:18am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
i think you'll probably find they replaced them with the old spec clutch (as was the case with mine). i read somewhere on one of these forums that the new spec clutches are actually quite reliable. www.ralton.co.za
Post #32096 13th May 2010 4:59am
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Hey guys any more details on the new clutch specs?
Cheers. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #32103 13th May 2010 8:06am
CapeLandy
South Africa
My dealer was confused as the 3rd clutch he fitted was different to the 2'nd uprated one in way of some plastic part/hub that was now metal.
Post #32114 13th May 2010 10:44am
dgardel
Italy
see 2nd pag. http://www.defender2.co.uk/gallery/albums/...1012-1.pdf
explain how recognize the OLD from the NEW version....
no plastic parts on it....
the modified parts are the springs Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32133 13th May 2010 4:16pm
lrdxb110
Thanks dgardel, going to try and get a new clutch under warranty from my lr dealer, gear rattle problem is back Big Cry '08 LR Defender 110
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #32311 15th May 2010 5:12pm
