- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > TD5 Intermittent Start Problem |
richardmcb
TD5 Intermittent Start Problem | |
My faithful TD5 is sensing that I might be upgrading to a new one soon and has decided to protest by failing to turn over and start. The problem is when you turn the ignition switch the starter turns over and then seems to stick or wont turn over at all. Try again and next time it will usually go. Battery is good and the problem might be worse when cold. Any ideas on where to start ? Could an injector be leaking diesel into a cylinder causing it to have difficulty in compressing on startup? Any things to check out first ?
Thanks
Richie
12th May 2010 9:23pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
