Home > Wheels & Tyres > Tyre pressures
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Tyre pressures
What's the consensus on tyre pressures? The b-pillar says 30/48 F/R with just passengers and luggage. 48psi seems a lot when there's nothing in the back.
Post #285020 25th Nov 2013 8:56am
MartinK
Yep, 48 in the back (unladen) rattles the fillings out.
I use 30 (F) and 40 (R), but have tried 38 in the back to good effect.
30/40 seems a good compromise in ride comfort without damaging fuel economy (!). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #285056 25th Nov 2013 10:59am
kirk
United Arab Emirates 2009 Defender 110 Puma 2.4 SW Blenheim Silver
Doesnt tire pressure depend on the tires the vehicile rides on? Mine has Goodyear ATs and I always thought 30psi front and rear would be a good number. Can't imagine putting 40 or 48 psi in those. I think they would explode.
Post #285145 25th Nov 2013 5:36pm
MartinK
In the Owners Manual is simply states:
...but as the OP states, 48PSI rear is far to rattly when unladen
48 rides well tho, when reasonably laden... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #285147 25th Nov 2013 5:45pm
CEEGEE
United Kingdom 2006 Defender 90 Td5 HT Cairns Blue
I've just put on some (new to me) wheels with General Grabber TR 235 85 16's, and wanted to double check the pressures.
Handbook says 29 psi front, 36 psi rear.
Also rang the local dealer who checked the advisory sticker on a Defender in the showroom with the same spec tyres, and he said it read 30 front and 38 rear.
Post #285150 25th Nov 2013 5:50pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Best way to check pressures for YOUR standard load, is to run a line of chalk accross the width of the tyre and drive over it on flat hard ground until it begins to fade... if the center rubs out before the edges, the pressure is too high and vice versa.
Aim to get an even fade accross the entire width Thumbs Up
Post #285151 25th Nov 2013 5:54pm
milesr3
Tyre pressure is just a product of the load on the axle and the tyre section. Interesting that the rear pressure in a 90 is 38psi. That has to be a good yardstick for an unladen 110 / up to 2 passengers.
Anyway 40psi feels a lot less harsh on std contis and as a bonus the headlights are pointing a bit further up the road. Thanks!
The Yokohamas on my Elise have little circular markers in the shoulder and you can tweak the pressures to wear right up to these. 0.5psi makes a noticeable difference in that, but I haven't got the same feeling for the defender! Very Happy
In my experience, handbook pressures err on the side of caution where the vehicle is driven at max speed and max load on cold tyres.
Post #285155 25th Nov 2013 5:58pm
I always run 32F 38R PSi.
Always worked off me on my 90 for general use. No Guts, No Glory.
Post #285156 25th Nov 2013 6:05pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
On my 90XS SW running pressures as detailed in the handbook, 30F 38R, I got wear in the centre of the tyre tread. Dropped pressures to 28F 34R produced uniform wear across the whole tread width. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #285188 25th Nov 2013 7:28pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I run my ninety at 30f/35r tyre wear seems even and has the added bonus of the CD player skips less Whistle 2005 Td5 90 XS
Steve
Post #285190 25th Nov 2013 7:35pm
Johnnyb0
I have cooper discovery STT 285 x 75 x16 on sawtooth alloys on my 90 and run them at 30psi all round. I'm normally one up and light laden. Anything more than that the ride is a bit harsh.
Post #289961 12th Dec 2013 9:35pm
Ibex
Interesting method, but you would surely need to do it when the tyres are warm after a run and they would cool down rather a lot during the test.
A method that I have heard of which seems to me to be a good one is, if you are prepared to buy a temperature sensor such as is sold by Maplin, go for a drive with usual load on the vehicle to get the tyres up to temperature, then stop and take temperature readings across the width of a tyre. If hotter in centre-line than near edges then drop the pressure and vice versa. Aim to get an even temperature distribution across the width of the tyre. Richard
Post #320804 1st Apr 2014 3:45pm
Pickles
Upon pickup of our Defender, we were advised that the pressures had been set at 30F & 36R. The service guy has been doing Defenders "for ever", & he thought that these would be good for normal every day use.
Cheers, Pickles.
Post #320937 1st Apr 2014 9:10pm
mick
I put 33 psi all round in a loaded up 130 on 265/75/16
Post #320950 1st Apr 2014 9:36pm
landy andy
I do 32 psi on all, but the spare.
Andy
Post #320953 1st Apr 2014 9:45pm
