Home > Technical > Rear mudflaps |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Probably a rivnut spinning in the crossmember. Use say mole grips and apply a downward force to extract existing bolt. Then after reading the thread on homemade rivnut tool just tighten up the rivnut. HTH
Brendan |
30th Mar 2014 6:55pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5861 |
On my 110 the bracket mounted to the chassis had a bolt going right through the chassis from one side to the other. 1999 Defender TD5 110
30th Mar 2014 7:48pm |
landiedave Member Since: 14 Mar 2013 Location: Welsh Marches Posts: 49 |
ok thanks, I'll check out to see if the bolt goes right through, but sadly I don't think it does and I'll check out the homemade rivnut jobbie.
Cheers Guys |
30th Mar 2014 8:29pm |
Not sure if it's a standard fitment or not. 1999 Defender TD5 110
30th Mar 2014 8:33pm |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
Given how most of the rivnuts seem to turn, even after the first fitment, this is how it should have been done in the first place. 1998 110 300Tdi White Hard Top |
30th Mar 2014 10:33pm |
I replaced one of the rivnuts on mine with a regular nut and bolt. With a bit of fiddling, it's possible to feed a 10mm spanner into the chassis through the nearby circular hole to get to the back. I attached a cable tie to the spanner in case I dropped it inside. Darren
31st Mar 2014 6:31am |
Maybe that's why I had no rivnuts on mine. Replaced with Stainless bolt/washers and nylock. And yes, that's how it should have been done! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
31st Mar 2014 7:56am |
