Home > Maintenance & Modifications > Brake caliper seals
Whitewaitress
Brake caliper seals
I'm changing the rear discs, pads & pistons on a 2007 puma, including the seals inside the calipers where the pistons slide along - although the thin metal ring covers for the top seals are proving to be a nightmare to get them to tap in gently and sit in the recess!
Has anyone else had any issues with these parts not fitting correctly? I know they have to be a tight fit but it's almost like the diameter is slightly too large - yet the pistons fit snug.
Any suggestions?
Post #319699 28th Mar 2014 7:45am
Have you "split" the calipers in half, or just trying to get the seals in whilst the caliper is whole?
I recently rebuilt the ones on the front of my 110, and it's a whole lot easier to have them in half (unbolting them), and yes, they are quite tight, but using that pink coloured rubber grease Shocked Embarassed makes it a lot easier.
Post #319703 28th Mar 2014 8:02am
Whitewaitress
Thanks Jim, I've split them yes - so they're nice & easy to work with thankfully. It's just getting them to sit flush & tidy thats the problem for me, plus a lack of patience.
I'll give the grease a go to help them in! How did you push them in? Using a clamp or another method?
Post #319710 28th Mar 2014 8:24am
jst
i used to use a large socket that sits over the seal to ease them in evenly.
now i dont bother, its cheaper in time to buy a complete caliper and do it that way. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #319753 28th Mar 2014 11:04am
Whitewaitress
Starting to wish I did just buy a new set of calipers now Laughing will give the socket a go!
Post #319766 28th Mar 2014 12:03pm
As what James says, a large socket that fits over the piston will push that dirt seal in.
As for the pistons themselves, if there's enough lube and they're dead straight, you can push them in by hand, but if they tilt a little bit then they usually jam in and need wiggling to pull out. a wooden hammer handle is handy to stick into the hollow bit to wiggle.
Post #319775 28th Mar 2014 12:44pm
I also nowadays tend to replace the complete caliper.
Those seals are complete s*ds to fit, especially if you haven't split the caliper.
Incidentally if you have split the caliper have you been able to source replacement "O" rings for the seal between the halves? This can be difficult.
Post #319776 28th Mar 2014 12:51pm
Whitewaitress
The socet trick worked a treat - thanks guys!
Re. the little 'O' ring seals when the calipers were split, they looked in good order so I kept them in - I've kept an eye for leakage but so far so good!
In future I'll go with new calipers Laughing
Post #322338 8th Apr 2014 9:22am
jimbob7
Yep, another who bought new calipers (all four Neutral ),re-fitted with proper silicon grease (IMO,Servisol is the best,bayE,Amazon or Maplins).Every year the caliper/pistons should have been cleaned with brake cleaner and re-greased,lazy ar*ed f*kin fitters Evil or Very Mad . Pov.spec,ftw. 2006, 110,TD5.
Post #322353 8th Apr 2014 10:40am
Retroanaconda
Aftermarket seal retainer rings are notoriously difficult to get into the calipers. It's common to bend a few.
I used a genuine set last time and all four went in no problem.
Post #322475 8th Apr 2014 6:44pm
Mo Murphy
As Retro says use Genuine or Lockheed seal kits. I have learned to fit the seal retainer in a vice using the big washer from the end of a radius arm bush. Leave the piston protruding about 3mm from the caliper, fit the wiper seal and the retainer over the piston, make sure all is square, fit the big washer over the end of the piston and squeeze in the vice. The washer pushes the piston down and then squarely pushes the retainer into it's slot. Right first time Thumbs Up
Compare this with a 75% failure rate and hours of frustration trying to fit good Lockheed retainer rings on the bench with a screwdriver Confused
50 Shades of Pennine Grey
Post #322524 8th Apr 2014 8:12pm
