![]() | Home > Maintenance & Modifications > Squealing Exhaust |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Nice pictures Andrew these for sure will help other forum members,
have you refitted the turbo yet with a new gasket or a upgraded one ? Give me a shout if you manage to locate a better replacement gasket id be very intrested in the final soloution you have come to. Also let me know if you did actualy find if the mating faces were out of shape. Regards Pete |
Pete
I have found a gasket supplier that has something suitable only thing is I have to pay for the tooling as the gaskets are tough little ![]() I have not had chance to check the mating surfaces yet but hope to later. I will keep you informed ![]() |
Found that the flange on the exhaust manifold had warped
![]() ![]() Click image to enlarge |
London Lad Member Since: 04 Jul 2008 Location: Suffolk Posts: 4 ![]() ![]() |
Thats a pain
At least you found the problem
![]() better than landrover all they can do is fit new gaskets lol |
Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119 ![]() ![]() ![]() |
Been there got the T-shirt Andrew! On my 2nd Turbo now and they realised that when they fitted that they hadn't tightened it properly, otherwise they would have fitted a 3rd..... Were you towing when it started sqealing? All 3 times I have had problems I was towing, but (and I am touching wood) it has been fine for the last 2 months, picked up a new digger and trailer today and towed it 30 miles home with no issues, which is nice! Also towed an Ifor Williams with
![]() Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
No it simply got noisier and noisier over time. I have machined the flange flat and will fit a new crap LR stainless steel gasket to see what happens. |
This is the turbo flange during machining.
Don't want to interfere Andrew, but I really think that you should have used something a little more refined than a Stihl chainsaw for your machining
![]() ![]() I know your shed is an agricultural building, but come on! ![]() Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
I dont know !! He may actualy do a better job than landrover of fitting a turbo even if it is with a chainsaw lol.. I must admit it does make you think what is going on considering Garrett is suposed to be the dogs danglies of turbos. Regards Pete |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
did LR fix this in the end Andrew ?
I noticed similar happening on mine. Pom |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
no all they do is put a new gasket in im currently in the process of having something made so watch this space
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
