Home > Puma (Tdci) > Disable alarm when truck is accidentally lock with a door op |
murrayb Member Since: 20 May 2009 Location: Hastings Posts: 20 |
Does anyone know if there is a way of disabling the alarm from sounding when you accidentally lock the truck with a door open? It's very easy to have the keys in your pocket and when moving kit about in the back of the truck for it to go off.... causing the horn to sound - normally for me at 2am or when setting off for a stalk
25th Mar 2014 11:33am |
I know on a Td5 if you have access to a Nanocom or the like you can disable the mislock warning sound, I'd be very surprised if it couldn't be the same on a Puma.
25th Mar 2014 12:02pm |
As far as I was aware, if you locked the motor with one turn of the key in the drivers door then you set the perimeter alarm and immobiliser but not the volumetric part, the part that movement inside the vehicle sets off the alarm.
25th Mar 2014 10:54pm |
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 |
I will try that at the weekend, cheers!
25th Mar 2014 10:58pm |
Have a read here http://www.defender2.net/forum/topic7681.h...tric+alarm
There is also a tip about taping over the sensor and using the remote as normal. |
25th Mar 2014 11:12pm |
