![]() | Home > Puma (Tdci) > Patriot rack fitting instructions |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 ![]() ![]() ![]() |
Anybody got fitting instructions for a full length Patriot rack to go on a 90?
Thanks |
Thanks John,
I've mailed them, if no luck I'll give you a mail. ![]() Steve |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2674 ![]() ![]() |
If it's the same as the 110. Then you build the outer ring, Fit the legs on, fit the long planks. Fit to vehicle. Then go round and tighten the rack properly. Don't bolt it up tight before you fit it to the vehicle.
Also, use a barrier between the bolts and the rack. This will stop the corrosion between the bolts and rack 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Cheers Walfy
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
Did you get the destructions
