![]() | Home > Puma (Tdci) > Buzz at 2500 revs |
carpenpa Member Since: 23 Apr 2008 Location: Cornwall Posts: 31 ![]() ![]() ![]() |
I have had this buzz too, the truck has just had the exhaust downpipe replaced under warranty - imagine if it was just a missing bolt - I will mention this to the service manager, and check the bolts regularly.
Other common faults that I have had are: ABS sensor fault from new - replaced Paint flaking off inside the roof gutter - due to be rectified Leaking into the passenger footwell - appears to be coming right through the bulkhead seal - due to be rectified Waiting for the EGR valve to pack up!! ![]() |
Tony_Hillerby Member Since: 03 Feb 2008 Location: Inverurie Posts: 36 ![]() ![]() ![]() |
Just found that bolt loose again after replacing it last month. Looks like the loctite does not work. It was just sitting there on top of the heat shield.
Will have to think of another way of securing it in place. Makes you think if that's coming loose whats next? Tony |
