Home > Puma (Tdci) > Pinion part number? |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Give Dan At Duckworths a pm with your Vin number and he can look it up for you
Cracking avatar btw |
21st Mar 2014 1:06pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6603 |
Yes I know I'm a party pooper but not a suitable avatar, sorry. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
21st Mar 2014 1:09pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17336 |
If it's a 110 or 130 the rear diff will be the P38-type unit with 4 differential gears (known mysteriously as a "4-pin" diff) and the seal is FTC4851.
I haven't checked the part numbers you quote but I suspect they're for the Rover pattern diff (as used in the rear of the 90), not the P38. |
21st Mar 2014 1:23pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2410 |
it is FTC4851 Puma 110" SW
21st Mar 2014 2:04pm |
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 |
ok, thanks for the advice. Now to chase down the part FTC4851.
22nd Mar 2014 10:27am |
