![]() | Home > Puma (Tdci) > Standard Rubber Flooring |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
Don't know if you are interested. But killer on here has new removed sets of rubber flooring for sale that he has removed to upgrade to carpet.
Andy |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20734 ![]() ![]() |
Give CSK land rovers a call.
![]() ⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
In my opinion it's horrible stuff. It falls apart and moves around over the floor.
If it comes as standard then fine but if you're wanting to fit some to one with nothing, if go with carpets and then get some over mats. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 ![]() ![]() |
In my MY13 XS SW the rubber matting just covers the boot floor, including under the second row of seats and the passenger footwell floor. Nothing other than paint on the rear arches. The matting is just thin, ribbed black rubber. Something a little thicker, or with better sound insulating capabilities, or which extended over the rear arches would be better. But being able to hose out the inside without getting any water on the seats and having it just drain out of the door openings is brilliant.
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 ![]() ![]() ![]() |
If its going to be a workhorse, stick with the rubber. This is very cheap feeling, but functional.
If its a family vehicle, with occasional work, definitely go for the carpet. The carpet is only a £150 option, and fits very nicely! It also covers the rear arches, which otherwise are bare painted metal... would look appalling in no time! The rear is carpet is also removable. If you want any pics of the carpet i can sort some out for you. After market, each piece of carpet is £100+ from LR! Fit rubber mats over the top of carpet ![]() |
Hifonics Member Since: 11 May 2010 Location: Bridgwater Posts: 63 ![]() ![]() |
No one seems to go an off the shelf replacement rubber mat set that covers the wheel arches. I really want something better for my 110 utility but dont want carpet. Guess buying a sheet from agricultural supplies place and cutting to fit will have to do.
Double Post
