Home > Maintenance & Modifications > Looking far a strong above door interior handle |
max peck Member Since: 30 Aug 2012 Location: Dubai Posts: 17 |
Hi ,
I Have MUD-STuff grab handles. They work fine. |
17th Mar 2014 8:56am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
Max, how did you fit them? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
17th Mar 2014 9:48am |
Fitted perhaps not the optimum way. The headlining and door seal get in the way.
I took the headlining off and used one of the holes for the existing headliner fastner and drilled a new hole into the gutter for the other fixture. I fitted with a bolt and some wide washers down through the gutter. Then put thr headlining back on followed bu the handle plus washer plus nut.luckily the bolt head didnt spin and I could tighten the nuts. not great cosmetically but helps herself to climb in. |
17th Mar 2014 12:51pm |
pepekleinhans Member Since: 12 Jan 2013 Location: Cape Town Posts: 25 |
I used one from a Fiat Uno, I had to cut the roof lining little bit so I could get the handle flush with the roof frame, drill 2 holes and screw it in, works perfectly, the wife is very happy now.
Cheers Pepe 2005 Discovery 3 HSE 2007 2.4 Puma Defender 1976 series 3 with Ford V6 engine |
15th Apr 2014 5:44pm |
