![]() | Home > Puma (Tdci) > intercooler / fuel consumption relationship? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
A small one, mostly noticeable in summer due to the air entering the engine being cooler, and thus the engine running more efficiently. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
It did on mine, around 0.3 l/100km.
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
ok - nothing to write home about
Definately no discenable difference in economy but a significant drop in engine running temperatures.
![]() Treat every day as if it is your last....one day you will be right!! |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2463 ![]() ![]() ![]() |
do you mean EGT or that one given by a Nanocom or equivalent? Puma 110" SW
Coolant water temperature figures when ambient temperature and driving conditions were the same before and after fitting (taken at 25 degrees ambient) Summer months obviously.
Page 3..... http://www.defender2.net/forum/topic13612....ntercooler ![]() Treat every day as if it is your last....one day you will be right!! |
