Home > Puma (Tdci) > Buzz at 2500 revs |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 |
Check to see if the bolt for the turbo heat sheild is missing, its readily accessiable and visable on the top of the manifold at the rear of the engine.
Tim |
10th Aug 2008 1:54am |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
Mine has just started doing precisely this as well...I'll just duck out and have a look Mahn
'08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
10th Aug 2008 6:42am |
Yes...a bolt has fallen out.
Thanks Tim Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
10th Aug 2008 6:50am |
No worries Mahn! Took me 2 weeks to find it!!!
10th Aug 2008 8:25am |
Well sorted.
I figured it wasn't a terminal noise. I am not surprised that it took you two weeks to track it down What ever happened to the concept of Loktite? I've jury rigged a washer and a longer 10mm bolt until the dealer can deal with it. All quiet for now. Good luck with your kazoo Ken I'm enjoying mine as well...I thought that the Disco was refined!!! After a couple of weeks I reckon this is a great tub! Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
10th Aug 2008 9:22am |
DefenderKen Member Since: 09 Aug 2008 Location: Northumberland Posts: 15 |
Guys I'm ashamed to say my mechanical expertise can just about see me check the oil and water and where to put the diesel in.
Can you give me any specifics? Yours humbly....... Ken Stornoway Grey 90 XS Focus C-Max Tdci Kawasaki ZX6R C6f |
10th Aug 2008 11:22am |
No worries Ken!
The bolt is right next to the Engine Oil Dipstick: Click image to enlarge Cheers, Tim Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
10th Aug 2008 12:03pm |
Fantastic!
Not only a perfect picture of what I'm looking for, but its from the other side of the world in less than 10 minutes of posting the question. This interweb stuff simply stuns me. You are a man amongst men. Cheers Ken Stornoway Grey 90 XS Focus C-Max Tdci Kawasaki ZX6R C6f |
10th Aug 2008 12:37pm |
Your welcome, and too kind Ken!!
Tim |
10th Aug 2008 12:47pm |
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 |
Sometimes a 10 hour time difference has its advantages - when you (UK) guys are at work, we (AUS) are sitting around bored with nothing else to do but spout random knowledge on-line. Just be aware though, many 10pm Australian posters may be a bit under the weather so don't trust everything you read 2007 Defender 110 1970 Alfa Romeo 1750GTV |
10th Aug 2008 11:32pm |
Tony_Hillerby Member Since: 03 Feb 2008 Location: Inverurie Posts: 36 |
Just checked mine out as I was getting a reverberating sound and guess what the bolt had come out. There was one there to start with as you could see where the washer had marked the heat shield. Fitted a new bolt with loctite so I will see if it stays in.
Tony |
11th Aug 2008 11:22am |
I don't know if Loctite will work because of the heat??? Strange how many have come out, must have been a stuff up on the production line?? If my one comes loose again I think I'll drill a hole in the bolt head and lockwire it in.
Tim |
11th Aug 2008 11:27am |
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 |
Just read this post and had not check oil for 1500 mile last Tuesday and when did check it i see that the bolt was missing to so just put new s/s bolt in with big flat washer and a good heavy duty spring washer also it's a m8 bolt thread not m10 as one_iota said would think you was going by the spanner size you use on the head
seems like LR should do something about this bolt to stop them all falling out Dave |
12th Aug 2008 11:58am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
I found the exact same problem on Japseronys car last week,
i was lucky eniough to notice it as i was fitting a Decat front pipe and replaced the bolt as per. I did think to my self at the time it seems weird that there is no bolt in there but obviousley there is a problem with these coming out. |
12th Aug 2008 12:45pm |
