Home > Maintenance & Modifications > Exhaust questions... |
What the CAT does is not the same as what the MOT emissions test is testing for, so absense of a CAT is not why you got a high reading.
If noise is your problem then fit a suitable silencer, as a CAT won't solve that either. It's good to hear that you passed the MOT without a CAT, given recent discussions on here. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
4th Mar 2014 7:31am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
With mine, I'm not sure it makes a difference to overall performance. (Strong stage 2 calibration) The differences are mainly throttle response and turbo lag. Obviously the reduced noise gives the impression of reduced performance. This is between cherry bomb and std silencer centre sections, no cat. 2002 90 Td5 Station Wagon
4th Mar 2014 5:13pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Thanks both, so LRA... so why do so many people remove the cat? I thought it was because it helps breath easier and helps the turbo to spool easier, and roughly how much power do you think I'd lose if I fitted a std centre silencer? 5 bhp, more? I guess that's the only thing that would make a difference to the sound?
It's not deafening, it's just a bit too 'throaty' sometimes, it gets raspy under acceleration and I'm not a boy racer any more. |
4th Mar 2014 9:34pm |
Yes, that's exactly why it's helpful to remove the CAT. It made a small but noticeable difference when I had mine done.
I don't know how much you'd lose by adding a silencer but, given the larger IC and tune, I doubt you'd notice much difference. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
5th Mar 2014 8:34am |
Ok, thanks, I'm tempted to buy a centre section and try it to see how much quieter it is, cheers
5th Mar 2014 12:29pm |
The Gribbin Member Since: 25 Mar 2022 Location: Tewkesbury Posts: 32 |
I know what you mean... I have tried various options from: straight through centre pipe; to cherry bomb from Alive; now got a 'Sports silencer' from Demand Engineering (at Peterborough Show)... each has improved, but still a lot of boom below 50mph.
90 TD5 Hard Top, well soundproofed in rear... Stage 2 tune. I am wondering what effect a larger bore straight through rear section would have... any trombone players on here!?... my theory is that might help expel the exhaust quicker, noise an' all?? Click image to enlarge |
3rd Apr 2022 3:30pm |
