![]() | Home > Td5 > Wipers |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Today I noticed my wipers weren't working as they should. Intermittent is working fine, as is normal and fast speed. When you nudge the stalk up for a single wipe, the wipers stop when you release the stalk, same when you turn off normal speed. When I turn off intermittent they park normally. My initial thought was that the park switch had failed but intermittent is still working correctly. unless there are two park stitches? 2002 90 Td5 Station Wagon
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
there's only the one switch, so that is a little strange. Faulty stalk?
Definitely not seized, new wiper boxes and cable put on a few months ago. They aren't slow at all, just don't park themselves unless on intermittent
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 412 ![]() ![]() ![]() |
Swapping the wiper motor is pretty quick so i would do that first.
There is a swict in the motor that senses the parking position . when i had to bang on the windscreen to get the wipers moving i knew it was time to change the motor. Cc |
Did you use genuine wheel boxes? I didn't at first and they lasted two weeks so replaced everything with genuine and no problems since. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17620 ![]() ![]() ![]() |
Most likely park switch and just coincidence that the intermiitent is turning them off in the parked position.
There's not much else it can be. |
Genuine wheel boxes yes, changing the motor seems pretty extreme to me, I'll start with the cheapest thing and work my way up I think
I'd say park switch, when it went on mine it was entirely random as to whether anything worked or not. Pov.spec,ftw. 2006, 110,TD5.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5822 ![]() ![]() |
On my Td5 I had a similar issue that they would park on intermittent, but not on wipe. So thought it could not be park switch, tried new stalk, new relay, no good. Then they stopped parking at all, new park switch, all good.
Andy |
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 ![]() ![]() ![]() |
Exactly same happened to mine about 2 months ago and it was the park switch, what you will probably find is that the intermitent will fail soon also. Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert..
I have been too busy to sort anything yet but was the park switch available from Landrover or did anyone have to buy one off the internet?
I'd rather get a genuine switch if possible ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I bought genuine,�25 ish (ferra pack of ten,
Have any left that you want to sell me?
/\/\/\ lol, I was being sarcastic bud, coz it's a frequent failure and should be considered a service items,like many other things,eg. cylinder heads, ABS pumps and chassis's.
