![]() | Home > Puma (Tdci) > Brake vacuum pump leak? |
get them to fit the latest pump which has a double seal 2.4 90 XS
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
They don't fail catastrophically.
They'll just leak to the point where the seal fails and oil is sprayed around quite a bit. If it isn't obvious (oil on the under side of the bonnet and around the pump itself) then don't bother taking it in - they'll need to be able to confirm the fault before replacing it. Sounds like yours is on the way out - they'll probably be able to diagnose it pretty soon. Make sure the latest part is fitted as a replacement (I doubt there are many of the older ones kicking about now anyway). One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Or spray some old oil all over the pump area... worked for me!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
I thought of doing that before mine failed ![]() ![]() + New Defender 110 First Edition |
