Home > Maintenance & Modifications > Roof light bar
Def Junkie
Roof light bar
I have recently bought a roof light bar along with 4 lightforce 140mms. Was wondering if there is a way to connect these lights without having to drill a hole in the roof. I have a snorkel fitted and have seen some posts saying the wire could be run along that but not sure how it will look and if anyone has done this? Any advice, much appreciated. Question
Post #309108 18th Feb 2014 11:26am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
run wire down inside of snorkel and straight under bonnett into cab is the easiest way use some nice p clips for the wire not gash cable ties. 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #309112 18th Feb 2014 11:47am
Cheshire110
i ran mine through the gutter where the clamp/bracket attaches and through the door seal into the car, then down A pillar, into dash where it meets bulkhead and from there you can go wherever you like (e.g. into engine bay through grommet) or you can go down B pillar and into seat box for the battery etc. Cheers, David
Post #309115 18th Feb 2014 12:14pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
I hate cables so drilled holes under lights and fed through centre of bar to another hole I drilled in the end then out through some conduit down inside RAI to under bonnet
Hope this helps Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #309170 18th Feb 2014 3:28pm
Def Junkie
Many thanks for all the tips guys. Very much appreciated.
Post #309440 19th Feb 2014 8:04am
Def Junkie
Guys, one more question if I may. How/from where do you run the wires from the engine compartment in to the dash? I have a 2009 Puma and the guys doing the wiring tell me the ABS unit hampers the routing of the wires from the engine to the dash. Any advice, very much appreciated.
Post #312817 2nd Mar 2014 8:58am
Cheshire110
if you open the bonnet, you'll see 2 large rubber grommets in the bulkhead. Use a straightened out coat hanger to feed through from engine side to where you can reach the other end (probably take the centre dash piece out and you'll be able to see it). then tape the wire to the coat hanger from whichever end you want to pull it through from and pull the coat hanger back. easy job really. Cheers, David
Post #312819 2nd Mar 2014 9:02am
Cheshire110
these are the grommets.
oval shaped with one large one in centre and 4(?) smaller ones outside. these can be cut out with a knife to allow cable to run through
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #312821 2nd Mar 2014 9:10am
I run all cables direct to the battery box as thats where my second/aux fusebox is underneath follow the chassis in quality weather tight abrasion proof conduit Thumbs Up
Post #312822 2nd Mar 2014 9:16am
Def Junkie
Much appreciated guys. I will give this a shot. Cheers.
Post #312904 2nd Mar 2014 3:20pm
