Home > Maintenance & Modifications > What Jack do you use?
Page 2 of 2 <12
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
High lift jack + 2 x stands for me, I would think no one in their right mind would get under on just a high lift jack! 90 & Wolf
110 XS
Previously owned SI SII SIIa SIII & Light weight (air portable)
Post #309638 19th Feb 2014 7:45pm
X4SKP
Thanks (so far) All...
I agree the LR supplied Bottle Jack (2010MY>) appears to be good enough (for its size) but does involve low level, (hands and knees) use to ensure its correct placement.
For Home Maintenance
My plan currently is to get the Defender up relatively high by using a combination of Vehicle Ramps a Hi Lift Jack and 'custom' Axle Supports.
To achieve this, I am currently 'Up-Cycling' 4 Ramps and in the process aim to deal better with the width of my tyres. The Ramps are around 30 years old (when most tyres looked to be <6 inches wide) but are basically a good starting point, the quick plan is to...
1 Strengthen the Ramps by adding some strategic metalwork
2 Make up some railway sleeper blocks on which the Ramps will sit
3 Make up some wider wooden 'ramp runners' that will engage onto the metal Ramps
The plan then is to use my new 'Hi Lift Ramps' then a Hi Lift Jack (5ft probably) to lift the raised Defender slightly more in order to support the Axles (securely) and get the wheels off.
Up-Cycle Ramps Project
I will update when progressed further...
Strengthened Ramps welded up and re-painted (2 part epoxy) / Oak Sleeper Blocks underneath
Next Step is to make up the wooden 'Ramp Runners'
Completed: 2 in action here, but with all 4 in use I can raise the Defender by 40cm (16") SKIP
Post #309766 19th Feb 2014 11:01pm
roel
At home I use a hilift jack or a trolley jack. My bottle Jack died.
The standard Land Rover versions off the hilift Jacks are useless in my eyes.
On and off-road I use Hi lift or air Jack depending on the ground I am on.
The air jack in sand is great. Under the sidebar and 2 wheels in the air in seconds. Roel
2003 90 Td5 (2009-now)
Post #309823 20th Feb 2014 8:38am
smb
Similar to Roel & BPMan, I use the LR Bottle Jack for quick roadside use and as part of a double lift with Trolley jack in Garage, All backed up with Stands of course.
For off-road I use the Hilift 48" which can also be useful as an added 'inching' winch and lifting out of ruts. But for quickness, in the fields and on sand I use an Ex-MOD Air-Jack made by Easylift AllTerrain. Fantastic bit of kit Thumbs Up Not sure of the horror stories around air jacks, but like anything else if your not paying attention and know what you are doing is easy to see how it'll go wrong.
I suppose at the end of the day it's whether you need the wheels off the ground for the type of maintenance you want to do. At least with the wheels in contact you have a better chance of the vehicle being safer and not moving.
Post #309879 20th Feb 2014 10:50am
Home use - trolley jacks, bottle jacks, HiLifts, or simply pick it up with the Iron Fairy (whichever suits the job in hand best)!
Away from home - bottle jack, HiLift, or airbag according to circumstances.
Post #309883 20th Feb 2014 11:18am
Piratepaul
United Kingdom 1989 Defender 110 200 Tdi SW Baltic Blue
Hi Lift 2 extreame , great although need a bigger footplate for it
Post #312411 28th Feb 2014 6:20pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
For planned maintenance, I use a two four post ramp. It helps to have friends with garages.
For unplanned maintenance/repairs, a three tonne trolley jack with a spreader beam(?) and some six tonne stands. It wasn't me!
Post #312511 1st Mar 2014 7:20am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
At home I use a trolley jack with axle stands. Outdoors I use the bottle jack supplied with the car.
I only use the hi-lift if I need the articulation on the axles, or outdoors only if I can't use the bottle jack.
Hi-lift can be a dangerous piece of kit!
Post #312541 1st Mar 2014 9:38am
Maybe one's not needed all the time:
Post #335737 4th Jun 2014 5:32pm
Grouse
I use the std LR bottle jack, works fine and takes up little room. I am not keen on the high screw jack - but it did once save me when I was stuck in a bog to enable me to jack her up to put rocks under the wheels.
If your bottle jack fails - check the oil level - don't just scrap it. 99% if the time it's just insufficient oil causing no hydraulic pressure
Post #336330 7th Jun 2014 8:42am
Post #337659 12th Jun 2014 7:24am
mk1collector
When using jacks DONT forget axle stands!
Post #337668 12th Jun 2014 8:07am
Call me paranoid if you wish, but whenever I am working under a vehicle I will use appropriate stands and in addition will make sure that there is at least one solid object (such as a ring of a tree-trunk) to provide a survival space in the event that the stands fail.
The risk with good stands is small, but the consequences are terrible. For the seconds it takes to add safety in this way it seems to me to be worthwhile.
Post #337697 12th Jun 2014 10:39am
mk1collector
Good call Thumbs Up
Post #337715 12th Jun 2014 11:38am
Page 2 of 2 <12
