Home > Puma (Tdci) > standard ride height....? spring colours...?
ngarigo
Ireland 2011 Defender 90 Puma 2.4 SW Santorini Black
hey guys...
can anyone give me an idea of standard height for a MY11 Puma 90 station wagon please.... measuring from the centre of the hub to the bottom edge of the spats.... mine is 485mm front and 500mm rear... I've been told it's too low and could cause me issues with driveline....?
thing is I've had the wagon since new and the only kit is an arb bar on the front...
also the colour coding on the springs is confusing me.... the front pair are both the same... red, green, orange... and the rear are the same... both, pink, green white....
aren't the left and right of the vehicle supposed to be different...?
having said all this.... she rides brill and drives wonderfully.... just curious and would like pice of mind because of the known issues with lifting/lowering the puma etc...
thanks...
image by Defender 90, on Flickr Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
'Wow...! What a ride!
MY11 90
Post #311780 26th Feb 2014 7:15am
MartinK
Spring colours are on this thread...2nd page:
http://www.defender2.net/forum/topic13312-15.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #311898 26th Feb 2014 3:36pm
ngarigo
so.... according to to that list I've got the wrong springs in....? Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
MY11 90
Post #312024 26th Feb 2014 11:43pm
LRI-Solutions
HI,
The springs that you have are standard Land Rover springs for your age vehicle, Land Rover changed from doing sided springs on 90 TDCI Defenders.
HD 90 tdci rears are red yellow green.
Personally I would leave them standard. Smile
Steve
LRI Solutions
Post #312088 27th Feb 2014 2:53pm
ngarigo
that's great...! everything I could find online was saying 'sided springs' thanks mate.... yep, definitely want to keep to standard I've no interest in a lift given the known issues with the driveline... I had been told that droop in the nose was just as bad though...? hence my original query... would be good to know what the 'safe' range is for ride height... Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
MY11 90
Post #312192 27th Feb 2014 9:43pm
MK
You can fit a RR spring isolator to lift the nose about 7mm Puma 110" SW
Post #312290 28th Feb 2014 10:19am
ngarigo
top idea MK.... couple ordered....! thanks mate... Wink Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
MY11 90
Post #312757 1st Mar 2014 11:00pm
Matthew_Mills
So what about the huge weight I've just added... Winch and bumper any ride height issues?
Post #312761 1st Mar 2014 11:37pm
ngarigo
hard to tell from that angle... best get the tape measure out Thumbs Up Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
MY11 90
Post #312776 2nd Mar 2014 2:08am
