Home > Puma (Tdci) > Why is air intake on side of wing and not the top?
Norm4n
Discuss..........
Post #311620 25th Feb 2014 8:23pm
bear100
rain water ingress? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #311623 25th Feb 2014 8:26pm
theorangebandit
Rain?....
Post #311624 25th Feb 2014 8:26pm
shaggydog
Rain, Snow, Leaves, all the reasons your heater intake blocks up- hence the snow cowl.
Post #311626 25th Feb 2014 8:29pm
theorangebandit
For me thr true question is why dont they come with an integral and water tight snorkel as standard?
Post #311627 25th Feb 2014 8:30pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Still toying with the idea of moving my air intake to the top of the wing and covering it with a snow cowl.
Post #311636 25th Feb 2014 8:40pm
Norm4n
Meee too!
Post #311640 25th Feb 2014 8:42pm
shaggydog
To be honest, very few people actually need them as most defenders live there life on dry land. If you are going in deep enough to worry about your air intake being submerged then most likely event is your ecu's are already underwater, along with your floor mats, Battery compartment, fuses, axle and gearbox breathers so the damage may have already been done.
I can't see how much difference a few inches will make in the long run
Post #311655 25th Feb 2014 8:59pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
The air intake used to be on top of the wing on 2.5 N/A and i believe V8. It moved to the side with the launch of the 2.5 TD engine. 2005 Td5 90 XS
Steve
Post #311658 25th Feb 2014 9:04pm
borderterrier
It's more about a clearer, shorter run for the intake of air than for extreme fording use.
Post #311756 25th Feb 2014 11:57pm
I think the intake was just on the airbox under the bonnet.
Post #311775 26th Feb 2014 7:00am
Naks
The major issue with the air intake's location is that it is right by the front wheelarch and sucks in all the dust when driving on gravel roads.
This is why most owners in Africa/Oz put on a RAI as soon as they buy a Defender.
You do not want to see an air filter after driving 1000km of Namibia's finest gravel roads without a snorkel Shocked --
Post #311783 26th Feb 2014 7:22am
Mountain_man
Wales
Correct. My pre turbo 110 has no side vents and no wing vent (other than the heater. All it had was the oil-bath air filter. The air was taken in around the top of the filter housing which was up near the top of the engine
Post #311793 26th Feb 2014 8:11am
borderterrier
Same as the 2.25 diesel in my S3
Post #311797 26th Feb 2014 8:22am
Mountain_man
Wales
Yep, my 110 was originally a 2.25 diesel too Smile. If you ever need a new air filter housing.... Very Happy
Post #311800 26th Feb 2014 8:39am
