Home > Off Topic > Not only Defenders are a very easy steal....
ericvv
Poor BMW owner was able to take pictures with telelens how his relatively recent BMW was stolen within 1 minute.
Happened in The Netherlands and the movie comments are in Dutch language, but still interesting to see how easy it apparently is. So not only Defenders......
In a nutshell, the comments are that the owners parked their BMW 320 and walked up a hill, smaller white Beemer parks behind them and touches their 320, 2 guys get out apparently checking if they caused any damage but in reality were checking if all was clear..., they both walk to the side of his car and owner thinks they are going to put a note with their name and phone number behind his wiper Laughing , but one guy just gets in and behind the wheel while owner starts running down the hill, and both Beemers drive off. The white Beemer had a stolen license plate. Mr. Green
So not only Defenders. Crying or Very sad At least many of us use pedal locks, etc. Thumbs Up
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #310785 23rd Feb 2014 6:51am
AWOL
Google "BMW stolen without keys" and you might form a view that they're easier to steal than a Defender...
Post #311091 23rd Feb 2014 9:36pm
Cheshire110
Don't get it. How did they steal the car? Cheers, David
Post #311113 23rd Feb 2014 10:14pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
By using a cloned key most likely. A blank programmed in the car being stolen through the OBD port.
As I understand it though there should have been a software change to prevent this so if it had been serviced that would be impossible. www.td5.org
Post #311175 24th Feb 2014 7:35am
^^ That's correct, the obd port will only allow you to clone keys with the ignition on (post software update) unless you are at a dealer with the full BMW service computer connected to the BMW network.
Shame Land Rover could not do something similar ... how hard could it be ???
Post #311191 24th Feb 2014 9:38am
munch90
make the obd socket live with ign on only ,not live all the time or have a switch ( hidden ) on the neg feed
a programmer cant work then
Post #311192 24th Feb 2014 9:42am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Reroute the original one to another place and place a dummy with enough volt running through it to burn the thief's laptop? Whistle Mr. Green
Post #311204 24th Feb 2014 10:27am
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Or even re-route and hide the OBD socket and have an immobiliser act as a break in the circuit of the socket, onlt making it live when needed by the garage or if you have one, a scanguage. Oh and as you say, wire up a fake OBD to the battery.
Post #311206 24th Feb 2014 10:36am
munch90
only thing with making obd socket live only with ign is some dianostic tools need you to switch on then off then on etc to talk to ecus .
move obd or switch in earth would be better . put a dummy one back in orringal hole so any one trying will think its just not working
usual thing applys if only you know is best
Post #311208 24th Feb 2014 10:44am
so, if it's that easy why do land rover not do it ?
Post #311218 24th Feb 2014 10:58am
borderterrier
Same reason they don't make them waterproof or secure the bonnets and doors I suppose!
Post #311220 24th Feb 2014 11:00am
borderterrier
Absolutely. I have a very complicated system in place now. Takes me 20 mins to explain the garage. Just hope the fitters are trustworthy Shocked I have a number of options if I feel the system has been compromised though.
Post #311222 24th Feb 2014 11:02am
munch90
to be honest I would rather it act normal rather then let anyone know
Post #311225 24th Feb 2014 11:09am
borderterrier
A thief wouldn't know, its vanilla unless you know about it. Totally passive too.
Post #311267 24th Feb 2014 1:55pm
Just chop the OBD socket off, solder on *another* type of socket, and make up an adaptor with the OBD socket soldered to the mating new plug to suit the one you just fitted.
Keep said lead out of the vehicle. then no-one can plug anything in!
Post #311294 24th Feb 2014 3:44pm
