Home > Maintenance & Modifications > Electrical part supplier
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
Can anyone recommend a quality electrical (wiring) supplier. I want quality over price.
Thanks
Gavin
Post #310511 22nd Feb 2014 9:41am
excossack
Vehicle Wiring products.
Mobile Centre
I've used this chap on ebay for Thin Wall cable > http://stores.ebay.co.uk/Kojaycat-Vehicle-...7675.l2563
I guess it depends what you are after? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #310520 22nd Feb 2014 10:15am
VWP and here for thin wall: http://www.ebay.co.uk/usr/roddas73
VWP are good for bulk but small orders and individual items cost more on delivery. KEEP CALM AND Drill ON
Post #310522 22nd Feb 2014 10:20am
gavinpm
Thanks.
In this instance I am replacing light bar mounted spots with an LED lamp on the roofrack - I want to break into the wiring with a waterproof plug and socket so lamp/roofrack can be removed if necessary.
And in general it's good to know a supplier who has quality components rather than cheap ones.
Gavin
Post #310525 22nd Feb 2014 10:24am
K9F
A marine chandlers can be excellent for sourcing top quality cable for the harshest environments. Really depends on what your plans are and where the cables are going to sit.
Personally I use Olflex Cable from Germany and available from Farnells it is suitable for just about anywhere on the Land Rover and available in different core sizes and multicore.
http://uk.farnell.com/jsp/search/browse.js...tid=229326
Cable Glands don't come much better than those offered by Index Marine. Side entry ones available too.
http://www.indexmarine.co.uk/deck-glands-se-series.php
Cannon, amphenol and just about any connector for any purpose PEI Genesis Southampton. You will of course need the tooling to crimp the pins sockets but I can possibly help you out as you're not a million miles away. 'PM' me if you wish I may have a few bits 'n' bobs lying around, dependant on your needs.
http://www.peigenesis.com/en.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310526 22nd Feb 2014 10:26am
gavinpm
Sorry gents I think I confused the issue by putting "wiring" in my original question - I meant wiring accessories and in this particular case an IP rated plug and socket to break into existing wiring.
Gavin
Post #310530 22nd Feb 2014 10:45am
gavinpm
BTW K9F - that Index Marine kit is quality.
Post #310531 22nd Feb 2014 10:46am
K9F
Google 'Buccaneer 400 Seies IP Connectors' and take your pick. Thumbs Up
http://www.ebay.co.uk/itm/3-PIN-400-SERIES...144wt_1197
http://www.ebay.co.uk/itm/Flange-mount-soc...1251wt_960
Or look here under connectors and scroll down to weatherproof.....
http://www.vehicle-wiring-products.eu/VWP-...ectors.php If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310548 22nd Feb 2014 12:11pm
gavinpm
Perfect - thank you K9F.
Post #310565 22nd Feb 2014 2:10pm
