Home > Maintenance & Modifications > HID conversion kit
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
HID conversion kit
Is it possible to fit these HID conversion kits to the 2007+ Defenders?
If so, any special precautions / notes?
(i won a kit and would like to install it..., or else sell it if i can't).
Post #30729 26th Apr 2010 10:44am
K9F
Few topics on HID headlights if you do a search....Not sure what you mean by "these." Legality may be an issue and will have to be considered too (maybe)...
http://www.defender2.net/forum/topic2877.h...conversion
http://www.defender2.net/forum/topic479.html?highlight=hid
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30738 26th Apr 2010 12:40pm
Naks
Re: HID conversion kit
ralton wrote:
Is it possible to fit these HID conversion kits to the 2007+ Defenders? If so, any special precautions / notes? (i won a kit and would like to install it..., or else sell it if i can't). Cheers
Ralton, I fitted clear Wipac headlight units to mine, cost me R1350 including brighter bulbs.
Post #30740 26th Apr 2010 1:08pm
ralton
I am a little confused, so please bear with me. I have read through many posts on this and the SA forum on HID kits. There are quite a few conflicting opinions, so let me ask a few questions:
Firstly, "these" refers to HID7 light kit, with 2 balasts, bulbs and cables. 6000 Kelvin. (or is there more to it than that?)
- is the headlight on the 2007 Defender a sealed unit? Or does it use a halogen type bulb that clips into the back? And is it physically possible to fit this kit to the standard headlight unit?
- does anyone know what the South African law is regarding these HID kits?
Post #31013 29th Apr 2010 8:37am
Naks
no, it is not a sealed beam unit.
You can clip/unclip the bulb from the unit.
I would not fit an HID kit to the standard unit - HID kits will blind oncoming traffic because the reflector unit in your Defender OEM headlight is not designed for HID light.
Raltom, I paid R1350 for a pair of Wipac clear lenses including upgraded bulbs,, and it makes a HUGE difference! You can contact Andrew Faber from Chuma 4x4 on andy.faber@vodamail.co.za if you're keen.
Also, bear in mind that if you HID kit bombs out in the bush, there is no easy fix! With the Wipac setup, I can carry spare Osram bulbs and replace them anywhere in 20mins! Thumbs Up
Post #31016 29th Apr 2010 8:41am
ralton
[quote="Naks"]
ralton wrote:
- a pair of Wipac clear lenses including upgraded bulbs,,
Thanks Naks
The ONLY reason why i'm exploring this is because i won a kit from Leisure Wheels magazine for an article i wrote in the May issue... If i can't use them then i'll just sell them on Gumtree or something...
Post #31017 29th Apr 2010 8:50am
Naks
ralton wrote:
The ONLY reason why i'm exploring this is because i won a kit from Leisure Wheels magazine for an article i wrote in the May issue... If i can't use them then i'll just sell them on Gumtree or something...Cheers
Hmm, well, if it's for free, then you might as well put them in the Landy. But be aware that standard headlight reflector units will spead the HID light all over the place, very hard to focus these.
Do some googling and see what people have come up with?
Post #31018 29th Apr 2010 8:51am
LED's the way forward
Post #31036 29th Apr 2010 12:34pm
MK
Do you know why the Wipac clear lenses have an internal bulb cover? Puma 110" SW
Post #31045 29th Apr 2010 2:09pm
Naks
erm, no. I will check mine and confirm
Post #31050 29th Apr 2010 2:32pm
NoDo$h
If by that you mean a cover inside the reflector, mine don't Confused
Cracking lights when you fit an upgrade bulb mind you Thumbs Up
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #31058 29th Apr 2010 3:57pm
Naks
These are the upgraded headlight units:
Post #31065 29th Apr 2010 4:22pm
MK
Well, I got them from devon4x4 and they do have an internal bulb cover and also a small euro pilot light Question
Also sent with all bulbs Rolling Eyes
Uploaded with ImageShack.us Puma 110" SW
Post #31069 29th Apr 2010 4:51pm
ralton
apparently these are the headlights to fit if you want to get rid of the HID light scattering problem...
http://www.britpart.com/Accessory.asp?Page...ehicleRef=
Post #31115 30th Apr 2010 8:32am
MK
Anyone tried PIAA bulbs? Puma 110" SW
Post #31120 30th Apr 2010 9:48am
