![]() | Home > Td5 > Oil contamination in Air Flow Meter |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17713 ![]() ![]() ![]() |
Oily vapour from the breather in the cam cover via turbo and intercooler.
You can fit a catch can or filter in the pipe from the cam cover to the air inlet pipe to trap most of this. Think what the inside of the intercooler will be like! |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 ![]() ![]() ![]() |
Can the oil vapour flow against the air flow through the air filter, the oil vapour comes in after the MAF and the pipe section ???. two way flow within the single intake tube ???.
I can accept the oil is from the vapour , how can it travel against in the air flow which is created by the turbo |
Sorry, I was thinking of the MAP sensor not MAF.
Dunno then! |
