Home > Maintenance & Modifications > LR Raised Air Intake
Matthew_Mills
Today I fitted a LR RAI...
I know, I paid more than a Mantec would have cost, but I like OEM kit (even if someone else made it...). I prefer the shape and the black upper mount - looks great.
But god I hate drilling holes in my new 100 XS Station Wagon...
Anyway I spent a few hours last night before picking it up trying to find some instructions - to make sure I had all the tools. But even Google let me down and I could not find anything - I assumed the Mantec was similar and borrowed a Viv-Nut setting tool. I needed it as i'm sure most of you know.
So I thought I'd scan and upload in case anyone else needs to find them. There's no copyright so no issue - Unless Martin feels differently - which I totally understand if they are removed but I hope not.
I've also read all of the other - you need to 'seal the internals' posts...
Thus far I did release the torqs and sealed the inter ring element - I'll do the pipes and drain holes etc., at some point too.
Mantec bumper and Zeon 12 next - any guidance on that front?
Matt
[/img]
Post #310037 20th Feb 2014 8:34pm
I think it has been known to be possible to bond the A pillar bracket to avoid drilling, at least I think that's what K9F did.
Mind you it has to be a really good bonding agent! KEEP CALM AND Drill ON
Post #310038 20th Feb 2014 8:38pm
Matthew_Mills
Customer90Steve
Done now... drilled the 'A' post and wing and inserted the RivNuts. I don't plan removing it, so no worries. I did waxoyl all the holes and used a tar based sealant on the gasket which never hardens fully. So hopefully a job done well!
We'll see - annoyingly found 2 chips in the windscreen and 3 on the bonnet already - checker plate maybe!
Matt
Post #310047 20th Feb 2014 8:46pm
TJ101
Well
I only know one Matt Mills Shocked
Are we taking a 110 or a Trayback ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #310075 20th Feb 2014 9:34pm
Matthew_Mills
TJ101
Mine is a 110 Station Wagon, previously on this site with a 90 XS SW and before that a 90 TD5...
Not sure we know each other?
Matt
Post #310081 20th Feb 2014 9:47pm
TJ101
My mistake Matt,, Rolling Eyes
Must be 2 Matt Mills in Somerset then,, thought a new 110 is not the Matt style i know ? more like a bowler or similar
The LR RAI, is made by Mantec,, as is the LR winch bumper,,
I have the same, so the exterior, visually looks as per LR official fitted accessories,, for a reason Whistle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #310092 20th Feb 2014 10:16pm
K9F
I did indeed....Sikaflex was my weapon of choice. Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310095 20th Feb 2014 10:26pm
Matthew_Mills
Great minds!
Yep, but I think the LR version is better in terms of the upper bracket, shape, and the gasket configuration...
As for the bumper - yep knew that, but LR do not have a Zeon version!
Mine arrives in a week or so...
Matt
PS I'd love a bowler! Mt wife would not! Rolling with laughter Rolling with laughter
Post #310098 20th Feb 2014 10:31pm
Good good, glad you got it protected well, that can be the issue with corrosion. Keep an eye on the bracket too. Other than that it should be trouble free. Wink Any photos fitted? KEEP CALM AND Drill ON
Post #310099 20th Feb 2014 10:31pm
Matthew_Mills
Pic fitted...
Rear work light and new style under shield... That's all now.
Zeon 12, Bumper, and new Head lights on the way...
What else - Hmmm, let me see?
Matt
Post #310104 20th Feb 2014 10:41pm
JWL
The same instructions are found buried in the public access part of Topix in the accessories part
http://topix.landrover.jlrext.com/topix/vehicle/index?cat=OWNER#
Along with other fitting instructions.
Post #310107 20th Feb 2014 10:56pm
Matthew_Mills
JWL
Now that's a revelation I knew nothing about that site - cheers I'll bookmark it!
CHEERS...
Matt
Post #310109 20th Feb 2014 11:04pm
Love the 110. Thumbs Up Probably passed you at some point on the roads unless your down in the Deep South. Laughing KEEP CALM AND Drill ON
Post #310112 20th Feb 2014 11:19pm
