Home > Maintenance & Modifications > Headlamp Levelling Motors
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Just changed my bulbs to Osram Nightbreakers, taking the opportunity to change the headlamp bezels (already rusted through after only two years) to stainless steel ones. No biggie, other than that I was obliged to remove the headlamp fixings to remove the bezel, disturbing headlamp alignment.
I intended to take the vehicle today to a local garage with a beam setter to finish the job properly, but the headlamp levelling motors no longer seem to operate.
Any clues as to what I've perhaps disturbed?
Peter
Post #298945 14th Jan 2014 11:37pm
spudfan
Ireland
When my 2008 was purchased new, the headlamps would always come on pointing at the ground very close to the vehicle. After driving for a while the motors would operate of their own accord and raise the lightbeams up to normal levels. When the ignition was turned off the lights would go back pointing low again. The motors were changed under warranty and everything worked well after that. Nobody else seemed to have this problem but faulty motors would not be unknown. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #309408 18th Feb 2014 11:39pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Stating the obvious - but did you unplug/disturb the connector onto the motor?
Post #309418 19th Feb 2014 12:30am
