Home > Puma (Tdci) > Puma Instrument Panel Warning Lights..How many?
Pickles
According to the "Quick Start" manual supplied with our '13 Puma, there are 12 warning lights, which as a "safety check", should light up, when ignition is in position 2. These warning lights are for, seat belt reminder, park brake applied, glow plugs active, traction control operating, differential lock engaged, heated rear screen, DPF (2) full, & approaching capacity(probably wouldn't be applicable because we have no DPF, hazard warning lights, trailer attached, headlight high beam on, rear fog lamps on. NONE of these show (light up).
What Do light up are, Red oil light, red battery light, yellow engine light, handbrake warning light, ABS, T.C., & a yellow "dot"?
Just wondering if any Puma owners could advise what lights light up when your Puma ignition lock is in position 2?
Thanks, Pickles.
Post #309089 18th Feb 2014 9:33am
Pickles
No-one knows how many of their dash warning lights light up before start?
Pickles.
Post #309353 18th Feb 2014 9:05pm
I'll take a photo tomorrow but what you currently get is from memory exactly what I get.
Post #309355 18th Feb 2014 9:15pm
theorangebandit
Ill throw up a photo too if I remember but I have to say I dont have seat belt warning lights but maybe a pic might be of use to you any how
Post #309367 18th Feb 2014 9:40pm
landy andy
I think the same as yours, not what LR are saying.
Andy
Post #309374 18th Feb 2014 9:45pm
Cheshire110
Mines a 2.4... I get:
- handbrake
- abs
- oil
- battery
- engine management
- fuel sender (shows glow plugs warming, goes out after few secs- you shouldn't start before it goes out)
- TC
They all go out upon start except ABS which goes out when you reach 5mph.. (Also handbrake obviously if not disengaged)
Hope this helps, mines a 2.4 but probably the same... Cheers, David
Post #309412 18th Feb 2014 11:49pm
Pickles
Thanks for the response chaps, the manual is completely wrong. I went into my Dealer's today & checked another new Defender, a 110,...exactly the same lights lit up as mine, so I don't know where the manual get's its 12 lights from?
Cheers, Pickles.
Post #309423 19th Feb 2014 4:38am
GUM97
Is this about right?
 An engine to TDi for!
Post #309491 19th Feb 2014 12:24pm
Naks
Yep, I have the same lights that come on. --
Post #309496 19th Feb 2014 12:43pm
Pickles
That looks about right to me,...I don't know where the manual gets its 12 lights from? Check your manual & see what it says?!
Thanks, Pickles.
Post #309703 19th Feb 2014 9:07pm
theorangebandit
Perhaps that page was cut abd pasted from the transit user manual??
Post #309709 19th Feb 2014 9:14pm
On turning the ignition on:
and then after about 5 seconds the abs, low fuel & traction control go off, leaving:
Glow plug indicator did not come on as engine was already warm.
Post #309767 19th Feb 2014 11:03pm
