Home > Maintenance & Modifications > How much for a new clutch in a TD5 110CSW
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
Just wanted to know if anyone could help me as I am after some quotes to change my clutch in a 110 CSW TD5. Its currently making a whirring sound when i put my foot down on the pedal before engaging gear and I think there is a bit of slipping near third. I think its the release bearing but it would make sense to replace the clutch at the same time!!
Can anyone give advise?
Post #309014 17th Feb 2014 10:13pm
Tiger
£800
Post #309018 17th Feb 2014 10:20pm
charliebaja
Is that parts and fitted?
Post #309020 17th Feb 2014 10:27pm
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Tiger wrote:
£800
with the flywheel as well?
Post #309027 17th Feb 2014 10:39pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
A couple of years ago we took an old Td5 Disco in Part/x which needed a new clutch as it was slipping.
We bought a clutch kit from Bearmach for about £50 and paid a local one man band mechanic £250 to fit it whick took a day (not a bad days work) so total £300 ish.This of course did,nt include a DMF. 2005 Td5 90 XS
Steve
Post #309028 17th Feb 2014 10:40pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hi Charlie,
Get a second opinion, mine makes a horrible whirry noise too. Mainly first thing in the morning when cold, it is the spigot bush I believe. Even new ones have done it I believe, mine has for 4 years and its fine.
Steve
Post #309029 17th Feb 2014 10:45pm
Lou Sparts
Spigot bush noise is standard fit on a Td5 but don,t worry about it because when the fuel pressure regulator leaks the diesel runs down the back of the engine and into the bellhousing and lubricates it Whistle 2005 Td5 90 XS
Steve
Post #309032 17th Feb 2014 10:51pm
Tiger
Yep, clutch & DMF was £800
Post #309034 17th Feb 2014 10:52pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
New spigot bushes don't squeal if you put a tiny bit of loctite on them when you put them in Thumbs Up
Post #309064 18th Feb 2014 7:07am
