Home > Technical > TD5 problem, help please
Page 2 of 2 <12
RichyB1967
United Kingdom 2002 Defender 90 Td5 PU Aintree Green
Thanks Laurie,
Will look into buying a battery tomorrow.
Richy
Post #308626 16th Feb 2014 4:45pm
Laurie
Ideally get an OE one or a good rated equivalent.
Post #308627 16th Feb 2014 4:48pm
RichyB1967
Does anybody know if the power relay energises when the engine starts only?
Post #308631 16th Feb 2014 4:56pm
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Sorry, just read your first post. Doesn't sound the same.
Doh, ignore me!!! 2006 Defender Double Cab- Zambezi Silver
Post #308648 16th Feb 2014 5:31pm
Laurie
My connection on the solenoid was very loose and occasionally prevented the starter motor from working but couldn't possibly cause Richy's problems.
Post #308654 16th Feb 2014 5:37pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
Sounds like power control relay has an earth issue, tried cleaning the earth inside the seat box? There's a black wire with a ring terminal that bolts to the bottom, this can cause issues. The last one I had this issue on was due to a broken earth wire between the inertia switch and the main relay, cured with an overlay harness Thumbs Up
Post #308678 16th Feb 2014 6:26pm
Laurie
There's a grommet on the front inside wall of the seatbox.
Originally this had wire running through it to attach an earth wire from the ECU to the engine (bellhouse flange)
This was dropped in later models. It's worth reinstating.
Post #308683 16th Feb 2014 6:32pm
RichyB1967
Solved it, the earth or ground was poor to the body. I was getting high resistance between the neg term on the battery to the chassis, and used a jump lead to the seat box to establish a good connection, and it started first time. Thanks for all the advice. I now need to reconnect the earth from the tow connector as it had failed.
Post #309421 19th Feb 2014 3:15am
Page 2 of 2 <12
