Home > Maintenance & Modifications > Washer nozzle
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Washer nozzle
I snapped my washer nozzle today while changing the windscreen rubber, the black plastic bit with the 2 small direct-able jets, does that mean that I have to replace the whole jet or just push another one into it?
I've been told that to fit a new one I have to remove part of the dash to get it to fit, is that correct?
Post #308467 15th Feb 2014 10:29pm
Weston18
England 1999 Defender 110 300 Tdi DCPU Tonga Green
I have been told of two ways of doing this job.
One- Told by a LR Tech, Heat up the new one in a bowl of water to remove the end any then place it onto the part stuck on the bulkhead. Apparently its two part.
Two- Remove the dash top and do it from there, Its easier with two people as one can hold steady from the outside whilst the other one places the nut on the back of the washer jet, Removing the top of the dash is not as tricky as people make out and can be done in 10-20 mine. Its a frustrating little job though.
Post #308469 15th Feb 2014 10:40pm
munch90
always done it by method 1
Post #308470 15th Feb 2014 10:43pm
JWL
If you've got the time and the inclination it might be an idea to consider this; http://www.defender2.net/forum/topic11649....washer+mod
Post #308486 16th Feb 2014 12:18am
Lambley
Thanks for the replies, I managed to get one at the Donington show today for £4 so I'll have a go at fitting it later. Cheers
Post #308615 16th Feb 2014 3:50pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
The tip I got from and Inde was to super glue it back together. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #308751 16th Feb 2014 9:38pm
roel
Mine was also broken and I glued it together as it was friday evening before an offroad weekend. And it worked and it is still not replaced. Roel
2003 90 Td5 (2009-now)
Post #308798 17th Feb 2014 6:53am
K9F
Mine too kept becoming dislodged on a frequent basis. The base only has a small contact area with the nozzle. To increase the contact area I sealed a flat rubber washer over the base and then subsequently sealed the nozzle back on, it gave a much sturdier foundation for the nozzle itself to be supported on.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #308831 17th Feb 2014 11:42am
