![]() | Home > Maintenance & Modifications > Refresh and enhance bog standard TD5 90CSW - Help? |
mudplugger Member Since: 28 Jul 2007 Location: err... Nr. Inglewhite, Lancs. Posts: 4 ![]() ![]() ![]() |
Hi,
We've a very bog standard, Caledonian Blue with white roof, TD5 90 CSW. It's been ours from new in March 1999, and has only done c.29,000 miles. There are now just a few rust patches appearing on the usual suspects (mainly rear cross member and rear corner strips) not helped by my other half having crinkled the rear offside corner when reversing. The ABS/TC lights are often showing the system as not working. Otherwise all is wonderful with the world. I want to take her (the D2, not the other half) into somewhere not too far from here who will properly sort out the damage and 'tart up' the wagon, give her a general spruce up and possibly fit some little extras that will help her survive at least another 8 years in our ownership without too much damage. So your help needed: 1. What extra little toys should we add? Factors to bear in mind are that the wagon is used for generally hauling my other half and her horse gear about when teaching. Very little towing is done now with the wagon. The use is generally country lanes/tracks and grassy fields - occasionally deep mud and/or water. My initial thoughts were raised air intake, A-frame & lights, sump/steering rod guard, rear bar/step and rear wheel carrier, perhaps some checkerplate sills/wing tops. Height is an issue with the garage, so don't want a roof rack! Part of me wants to give her the full off road treatment with a winch etc. but in reality it would probably never get used. We've tractors for serious off roading!! Any other suggestions/photos? 2. Where should we take her? We're just north of Preston Lancs. Nearest LR dealer is James Edwards (Brock) but our experience there so far has been mixed. Miss our old friend and best LR man John Williams in Clyro (Near Hay on Wye) - who always seemed to get things sorted at a reasonable cost. Interested in your responses to 1. so maybe over to creaator of the Gimp and perhaps Martin's encyclopaedic knowledge of all things Defender to give the benefit of which item is best and which manufacturer etc... As for 2. am interested in local knowledge up here in Lancs. Regards, Muddy One Land Rover is luxury, Two is just showing off... Defender 90 TD5 CSW Discovery 3 TDV6 HSE |
george130 Member Since: 14 Aug 2007 Location: Australia Posts: 20 ![]() ![]() |
If it's not for serious off road then Tires snorkel and diff guards are the go. A winch is very handy for more than just recoveries but you have to be carefull
![]() If you want to do serious stuff then dif lockers and a lift also make a huge difference. |
Le Rodent Noir Member Since: 16 Aug 2007 Location: Essex Marshes Posts: 23 ![]() ![]() ![]() |
...and if you are going to snorkel it up - remember to fit a wading kit too or your diffs will be full of mushroom soup....
![]() ![]() Cheers, Le Rodent Noir. |
