Home > Technical > my 110xs 2.2 puma euro v / nox, nox+ HC test fail... |
RockJaw Member Since: 15 Oct 2013 Location: United States Posts: 317 |
You're in Korea right?
You may want to redo the test when the wind turns upwind from your neighbours next door in China. I bet the NOX figs will improve significantly. ****CENSORED**** |
12th Feb 2014 9:17am |
ehehRoql Member Since: 12 Feb 2014 Location: seoul in korea Posts: 4 |
Answer Thank you...
12th Feb 2014 9:46am |
Hi ehehRoql,
Please excuse the long reply but I think possibly your issue may lie with the EGR Valve. This is based on an old reference posted by Dgardel. The EGR deletion or blanking bit you can ignore. Maybe worth getting it checked or giving it a clean perhaps? See below. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th Feb 2014 9:56am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Try a fuel additive,it's a common trick to do over here before mot,brings the emissions down can also clean injectors,EGR and turbo.Google "Forte diesel additive". Pov.spec,ftw. 2006, 110,TD5.
12th Feb 2014 10:48am |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 |
If its still under warranty, I would be taking it back to the local dealer and asking them to sort.
12th Feb 2014 10:35pm |
Try with 800cc of GOOD 2 stroke oil in a full of diesel.
in 90% of cases remedies Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th Feb 2014 10:08am |
thank you reply
and Please recommend good oil... ford (Ford WSS-M2C934-B) is not... other specs required? |
14th Feb 2014 10:47am |
We find the best results with Mobil 1 and Amsoil Series My personal preference is the Amsoil 0W30 for Africa and Asia and Mobil 1 5W30 for colder climates. Do NOT use aftermarket oil filters - big big no no no no!!! - use ONLY LANDROVER oil filters!! ****CENSORED**** |
16th Feb 2014 4:31pm |
^^ thank you
17th Feb 2014 1:40am |
Think your question is about recommendations for good 2 stroke oil (2SO) after this was suggested by dgardel, yes? Be careful, because the posts thereafter were not referring to 2SO at all, but to engine oil. Leave others who are more familiar with 2SO to answer, but a search would give you plenty recommendations too. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
17th Feb 2014 5:14am |
