Home > Tdi > Exhaust banging on gearbox
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
One of my first little niggly jobs I need to do is to stop the brand new exhaust banging on the gearbox, I assume when it was a 2.5 td the exhaust was a smaller O.D. from a 200tdi exhaust fitted now as the 90 has been fitted with a 200tdi engine but the exhaust is too rigid and can't move it as there is no room between the gearbox and exhaust so I am thinking although the engine and gearbox mounting rubber's look ok I think I will replace them but undecided wether to fit 2.5td engine mounting rubbers and gearbox mounting rubber's as fitted now or wether to fit 200tdi engine mounting rubber's and gearbox rubbers.
has anyone else had this problem and what was your solution Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #307047 11th Feb 2014 2:49am
cornish rattler
Anyone Smile Graham
Post #308241 15th Feb 2014 9:03am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Sorry, not had this issue.
Did have a problem on my TD5 after I belted the centre box on a massive rock. Not only did it flatten the centre box, but the force was so great it bent the rear section and also the front down tube. My point is that you might want to check the other sections to see if they are damaged and affecting the clearances.
Good luck
Simon
Post #308248 15th Feb 2014 9:33am
shaggydog
Does it have the standard defender engine or is is a discovery engine? In which case which pipe does it use from the turbo down pipe? (picture would be helpful) as I know some conversion kits are better than others and if its not angled properly or bodged in it can change the angle of the rest of the exhaust pipe and thus the rubbers which will lead to it banging or rubbing.
Also check the heat shield under the clutch slave as if this has rotated round or got bent could cause the same problem.
Post #308337 15th Feb 2014 3:44pm
cornish rattler
Good luck
Simon
Hi Simon
Its been fitted with a brand new defender 200tdi exhaust full system with a bracket that it welded to the exhaust and then bolted to the engine hence why its so rigid Smile Graham
Post #308425 15th Feb 2014 8:58pm
cornish rattler
Its a defender 200tdi with a full new exhaust system fitted with a bracket that is welded to the down pipe then bolts to the engine, hope this helps and I will check the slave cylinder heat shield is not damaged or loose Wink Graham
Post #308426 15th Feb 2014 9:02pm
cornish rattler
Good luck
Simon
Hi Simon
The down pipe I ment about the bracket sorry Embarassed Graham
Post #308427 15th Feb 2014 9:04pm
munch90
on my old 200tdi I fitted a flexi joint in exhaust ( cut pipe then slotted flexi in they tac welded so it was in right place then removed to weld round )
you can buy just the flexi joint from most motor factors, good make are bosal ones
measure pipe as they do lots of sizes
made a diffrence to vibration through body
Post #308435 15th Feb 2014 9:33pm
cornish rattler
Getting the engine / gearbox mount rubbers to sort this issue on Monday with a load of other stuff aswell and hopefully going to do everything next weekend Smile Graham
Post #312494 1st Mar 2014 2:02am
cornish rattler
Finally getting round to replacing the engine mounting rubbers tomorrow gearbox mount rubbers will be done next month Smile Graham
Post #316678 17th Mar 2014 7:55pm
cornish rattler
Here is a pic of one of the new series 2/3 engine mount rubbers that I fitted just before I replaced the timing plate Very Happy
 Graham
Post #318387 23rd Mar 2014 4:47pm
