Home > Td5 > TD5 idle mode when wet??
Page 3 of 3 <123
WorcsTD5
United Kingdom 2004 Defender 90 Td5 CSW Java Black
This is my master plan...
ECU pin 12 - white green - pedal connector F - sensor 1 - Green Trailer
ECU pin 36 - white grey - pedal connector K - sensor 2 - Brown Trailer
ECU pin 26 - black yellow - pedal connector D - earth - Black + Yellow Trailer
 (Black at connector D)
ECU pin 26 - black yellow - pedal connector G - earth - Black + Yellow Trailer (Yellow at connector G)
ECU pin 20 - red green - pedal connector C - sensor 3 - Red Trailer
ECU pin 14 - white purple - pedal connector B - supply 5v - Blue + White Trailer
 (Blue at connector B)
ECU pin 14 - white purple - pedal connector J - supply 5v - Blue + White Trailer (White at connector J)
Watch the news over the next few days for reports of a small vehicle fire in Worcestershire...
Post #306562 9th Feb 2014 4:30pm
Razler
United Kingdom 2002 Defender 90 Td5 HT Zambezi Silver
Landy Andy; Im too far North for floods, maybe heading further North soon in search of snow Wink
7 core wire is used but only 5 connections are made at ECU connector making 2 wires redundant.. Wire coming out of pin 26 (blk/yl) & pin 14 (wht/prpl) must have Y somewhere along the original loom, I Y'd mine behind the speaker.
My code was: (solid colours = trailer light cable)
GREEN - white/green
WHITE - white/grey
BLACK - black/yellow
RED - red/green
BLUE - white/purple
Post #306567 9th Feb 2014 4:42pm
WorcsTD5
Thanks for that Very Happy
My thinking is that by joining 2 of the trailer cores at ECU pin 26 and 2 at ECU pin 14, that effectively is the 'Y' that you mention.
or am I missing something...?
Post #306571 9th Feb 2014 4:51pm
Razler
Yeah see what your saying but my method reduces the trailer loom colours and when only working with 5v no need to double up early..
I cut the two wires of that were not going to be used flush with the outer insulation and heat shrink'd making it look nice and hiding the two wires not in use.
Under the speaker my BLACK fed the x2 black/yellow's & BLUE fed the x2 white/purple's.
Both ways will work..
I used the heat shrink with glue inside between the outer insulation and the wires but didn't have any of the small stuff for the wire soldered connections (the important bit) shame Big Cry
Anyways it worked and the electrical fire still hasn't happened, maybe its because I am stood here with the grenade pin pulled from the fire extinguisher Rolling with laughter
Post #306580 9th Feb 2014 5:17pm
landy andy
It does not matter where you do the join of the two cables, and can depend on whether you have five or seven core cable. Have done it both ways and always worked Thumbs Up
Andy
Post #306581 9th Feb 2014 5:20pm
WorcsTD5
Done it!
Ran mine inside the cab (along the back of the pedals, around the transmission tunnel, looped around the handbrake and into the ECU box).
Took it for a spin and found some righteous puddles that would previously have stopped it in its tracks...not a problem (so far!).
Many many many thanks to everyone who helped - Landy Andy, you are a driving God!!! Bow down Bow down Bow down
I'm a very happy boy Laughing Laughing Laughing Laughing Laughing
Post #306873 10th Feb 2014 5:11pm
Page 3 of 3 <123
