![]() | Home > Td5 > The wife has sprung a leak |
Usually an exchange box situation.
highbayrack Member Since: 06 Feb 2009 Location: Northampton Posts: 31 ![]() ![]() ![]() |
Thought so
Couple of leads for you:
http://www.powersteeringonline.co.uk/exchange_steering_boxes.htm Paddocks do an exchange service: http://www.paddockspares.com/sp/cat/DEFEND...Boxes.html Famous four do one as well on an exchange basis: http://www.famousfour.co.uk/new_parts/part...steer.html Bear in mind the exchange is only valid if yours can be reconditioned itself. ![]() ![]() ![]() If you fancy having a go yourself at the princely sum of £14:99: http://www.island-4x4.co.uk/steering-full-seal-stc2847-p-214.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Steering box? Oil leeking from the bottom of it?
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6150 ![]() ![]() ![]() |
From your profile i see you're in Northampton, not a million miles from Reading, where Adwest are, the people who actually make the PAS boxes.
Very resonable prices over the counter for a NEW (not crappy "rebuilt" with a can of black spray paint) and you get the drop arm & ball joint into the bargain as well. |
