Home > Technical > Discs and callipers
Page 2 of 2 <12
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Cheers for the reply Grafty - so, did you change the rear callipers too? I only changed the front to 110 vented. I think I'll be going for some braided hoses though.
Post #305757 6th Feb 2014 10:39pm
grafty99
Yes I put 110 callipers on the rear, the whole calliper is bigger
46 mm pistons as apposed to 41 mm and the pads are considerably larger.
Definitely go for braided hoses Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #305780 6th Feb 2014 11:23pm
grafty99
Just to clarify, 110 rear callipers on the rear of my 90 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #305781 6th Feb 2014 11:24pm
mpb
England 1996 Defender 90 300 Tdi SW Coniston Green
Are the 110 discs the same size as the 90, as I need to put new callipers on my 90 and 110 ones would be much better.
Many thanks
Martin
Post #307708 13th Feb 2014 9:52am
grafty99
I'm not 100% sure! I think the difference is in the off set of the disc rather than the diameter of it. But with fettling a 110 caliper should fit a 90 disc but please don't curse me if it doesn't Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #307815 13th Feb 2014 6:02pm
grafty99
Sorry, I assume we're talking rears? The fronts are the same, only deference being vented or not Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #307816 13th Feb 2014 6:04pm
mpb
Many thanks for that, it was the rear I was thinking of.
I'll have to get under the other halls 110 with a tape measure if it ever stops raining.
Martin
Post #307880 13th Feb 2014 8:36pm
Page 2 of 2 <12
