Home > Maintenance & Modifications > Prevent water ingress through grommet
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
Hi all
Any ideas on this ?
I have spots fitted to a light bar, which were installed just before I bought my 90. Over the months they have failed twice and I found it was due to the relay - which I thought strange.
As I removed the relay last time [located behind the instrument panel] - I noticed it was wet, but could find no evidence of any water, or anything else nearby being wet.
After a bit of head scratching I realised the only way this could be is by water making its way from the roof [through which the wiring leaves through a rubber grommet] and running down the wires all the way down to the relay. There is not enough ingress to cause damage to the headlining but enough to create a problem with the electrics.
After all that - is there a good way to make this wire entry into the grommet completely watertight ?
Thanks
Gavin
Post #304775 3rd Feb 2014 6:32pm
K9F
Sikaflex or a skintop gland if you wish to disconnect and feed the cables through the gland.
http://uk.rs-online.com/web/generalDisplay...nds#lappg1 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #304780 3rd Feb 2014 6:38pm
gavinpm
Jed
Thanks K9F, your advice (as in a previous posting of mine) is invaluable.
With Sikaflex would a liberal injection be what is required ?
Thanks
Gavin
Post #304788 3rd Feb 2014 6:57pm
K9F
Yes, smother the area and if you have a water spray bottle you can gently spray the Sikaflex and 'form' it with your finger to get it where you want it and a decent finish.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #304790 3rd Feb 2014 7:00pm
gavinpm
Great - many thanks K9F
Post #304798 3rd Feb 2014 7:13pm
