Home > Puma (Tdci) > Rear twin shock
Page 2 of 2 <12
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
Naks wrote:
Apynala wrote:
Could you explain why do you think it's a bad thing.Thanks
It's not necessarily a bad thing if you just want it. Wink
If you need it, then it means you are overloading your Defender, unless you drive uber bad gravel roads on an everyday basis for long periods of time.
When I drive my def in Offroad here in Morrocco on rock tracks I can fell it changing all along the day. We just carry what we need.
Why is it different to fit 2 OE shocks than 1 Koni raid?
Post #30358 21st Apr 2010 9:27am
MK
Not an expert, but if heating is the problem then you should get N charged shoxs or those with remote reservoir (they are expensive though). OE shoxs have some N in them, but I believe Koni are better. Search Koni on this forum as chap in Au has fitted them.
My advice is that you get proper shoxs from a local representative is case they fail. By the way, do not get anything from llama4x4 as his customer service is c#ap. Puma 110" SW
Post #30361 21st Apr 2010 9:51am
Apynala
Surely, but they are not available here. And if I need to change one I surely wait 6 or 8 weeks to get another one.
Post #30367 21st Apr 2010 11:54am
Glynparry25
Personally I would go down the remote resevoir route. I was looking at twin shocks but by the time you have ordered the mounts, fitted them and painted the axle after you might have well just ordered two sets of remote resevoir shocks so you have a spare set.
Also remember if you are going twin shocks you should change all 4 if only one breaks which will cost an arm and a leg.
Glyn
p.s. The Land Rover Snatch 2 and WMIK 2 both use remte resevoir shocks for desert driving- and they are normally loaded up to just short of 4 ton.
Post #30381 21st Apr 2010 3:35pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I don't think you could get a better reference than that Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #30382 21st Apr 2010 3:42pm
Apynala
There is a lot of choice on the shock absorber market. I'm sure that a lot of them are good enought for what I need.
I've fitted Procomp ES9000 on my last 110 300tdi and on the track one of the bushes broke. The bolt was welded by water, rust, mud and/or salt, I cut it with the rod. I Ordered 2 in the UK and I wait them 5 weeks.
That's why I would like to fit OE shocks.
Post #30386 21st Apr 2010 5:57pm
Naks
Apynala wrote:
When I drive my def in Offroad here in Morrocco on rock tracks I can fell it changing all along the day. We just carry what we need.Why is it different to fit 2 OE shocks than 1 Koni raid?
Apynala, I would suggest the Koni raid, rather than 2 OE, better suited for your needs Thumbs Up
Post #30449 22nd Apr 2010 8:30am
Apynala
I think you're right.
Thanks Glynnparry25 for your advise.
After looking to the Terrfirma twin shock mount, I think it's not good for lower bushes. The V mount couldn't be fitted to my def. So I've deceided to order good shocks.
Thanks
Post #30509 22nd Apr 2010 6:09pm
Page 2 of 2 <12
