Home > Technical > Switch for work light |
Can't help sorry, but very nice Defender! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
29th Jan 2014 9:32pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Have a look at the light - it may have a switch on the light body and the light may come on with sides or when the vehicle is in reverse ... just a thought .,., Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
29th Jan 2014 9:36pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2214 |
If it's not wired and no switch , then keep it easy and take it down to the rear window de mister . The wiring and switch is already there . That's presuming you don't use the window .
29th Jan 2014 9:47pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
If a land rover work light there is a big turn switch on the back of the light body usually powered as ignition live so cannot be left on - that's my guess
Heated mirrors is a guess of how wired as DIY fitment but very nice this weather - usually wired with front screen Looks 2020 P300 HSE |
29th Jan 2014 10:02pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
ooohhhhhhh hand me the tissues My 109 thread my youtube channel |
29th Jan 2014 10:20pm |
Had one of those lights fitted to me 300tdi 90, as pjb says large turn switch on rear. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
30th Jan 2014 10:48am |
otter-spotter Member Since: 11 Feb 2013 Location: Scotland Posts: 37 |
Think dealers sometimes put the switch on the inside immediately behind the light itself - I guess you have already looked there though!
Edit: This is sometimes installed as an addition to the switch on the light itself 300 TDi 110 CSW Last edited by otter-spotter on 30th Jan 2014 1:23pm. Edited 1 time in total |
30th Jan 2014 11:29am |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Awesome looking truck! Yes as mentioned the light is switched at the light itself, on the back.
As for heated mirrors, brilliant, when did they get added to the XS/Winter pack? Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
30th Jan 2014 12:02pm |
jumbo Member Since: 21 Jan 2014 Location: Dublin Posts: 29 |
Hi all, many thanks for all your kind replies.
Yes, the mirrors are linked to the heated window and Arc & PJB, you were correct, the switch is on the back of the light. Did 500 km in it today, great fun and enjoying it immensely. The only negative that I have is the LR stereo, it's c..p! Thanks again, Jim |
30th Jan 2014 5:27pm |
Click image to enlarge |
30th Jan 2014 6:29pm |
Thats the one Supacat. By any chance, do you know the make as I have dismantled it because it's not working.
30th Jan 2014 7:16pm |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 |
Its made by Lucas! Normally the bulb has blown if its not working, failing that its a wiring fault or dirty contacts on the switch through lack of use!
30th Jan 2014 7:34pm |
Thanks for that, changed bulb, so will strip down switch in the morning.
30th Jan 2014 8:01pm |
it's the one sold by lr as an oem item. usual suspect when not working is the switch contacts being out of alignment with the rotating knob. |
30th Jan 2014 9:56pm |
