Home > Tdi > MPG
Page 2 of 3 <123>
g-mack
taazzukcb wrote:
what app you using? cheers My 109 thread
my youtube channel
Post #303441 30th Jan 2014 4:17pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
FuelLog
I use the same, it's pretty good
Post #303456 30th Jan 2014 5:11pm
Spookytooth
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
No, not just mine, any 110 2.2 110 SW Aintree Green
Post #303471 30th Jan 2014 5:35pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
On my last fill up, I averaged 28.7mpg BUT this was over 650 odd miles (I put 2x 20l in as well) and for the first 490 miles, the air filter was filthy... previous tank with bad air filter averaged 26mpg, so on that basis, I must have been doing nicely into the 30s in the last 160 miles of previous tank.
I'll be filling up again in the next few days, to see what it's done entirely on a clan air filter.
I have been convinced that on a few trips to Norwich and back, I've been into the 30s... 1998 110 300Tdi White Hard Top
Post #303572 30th Jan 2014 8:51pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Mine is a 98 and on an empty run up the motorway I get about 31 or 32 with gnarly tyres or 32 or 33 with roadies. In town about 26 or 27 regardless of tyres or load. With the loaded big trailer 18 to 20 is fine. Rhubarb and custard let fly with their secret weapon.
Post #303638 31st Jan 2014 5:50am
Caterham
spookytooth - not saying you're wrong but lets just say I wouldn't be suprised if you're not right Very Happy
as mentioned elsewhere (500 is possible) I can get well over 30mpg. Not sure who else on there has exceeded 30 or if they're running a 2.4 or 2.2....I'll go have a look. but your statement raises the question of why the 2.2 is less economical as I thought it was supposed to be more economical?
just found this from Phil.....
hi,
just read this post today
if I am not wrong, 9.72 l/100 km is 31 mpg
this is the mean value for my defender 2012 with the 2.2 engine
I have always be interested with this kind of sport
but I see that I have a lot to learn when I read your performance !
and I have to say that I am driving slowly at a speed approx. between 90km/h and 95 km/h on highway what should be 56 to 59 mph
he goes on to mention 33mpg (if I remember right).
Post #303651 31st Jan 2014 7:58am
Spookytooth
Hi, take it all back, big apologies, misread the post and didn't realise the discussion was reference the 'sport' of driving for high mpg, my comments were aimed at everyday driving. Even I can easily exceed 30mpg on my night drives to Ashington deliberately going slowly because I don't want to get there before family wake up, however, still no way I can claim my Defender does more than 30mpg
In the real world no one will exceed 30mpg in a 2.2 over an extended period of time and although each to his own, it seems a strange thing to want to do more than once, far better to buy a Prius. High 20's is wonderful for me after my Series Land Rover and even after my Discovery
Anyway, each to his own and apologies for jumping in without understanding the direction of the thread. Will continue to read with interest and good luck on continuing to break the record
Out of interest is everyones fuel gauge the same as mine. Doesn't move for the first 100 miles, still showing half full towards the 280 mark and then only does 120 or so for the last half (not exact, however, sure you get my drift) 110 SW Aintree Green
Post #303670 31st Jan 2014 9:09am
Caterham
no offence taken what so ever.
I had meant to ask / put a general note up for those that are getting what I refer to as poor economy to see if perhaps they had a fault MAF sensor as my understanding is it isn't uncommon for user to have faulty MAF sensors that only really show (from what I've interpretted) by reduced MPG?
as you say the 'sport' of economy......just hoping I'll be able to crack 600 miles on one tank soon.
Thumbs Up
Post #303673 31st Jan 2014 9:30am
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Would a snorkel help with mpg as with a snorkel fitted the engine would be drawing in cold air that's being rammed in as appose to drawing in air from the side of the wing as at high speeds I don't think the original air filter system would draw enough air in making the engine struggle for air giving low mpg ? Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #304152 1st Feb 2014 5:36pm
Caterham
If I remember rightly bas did some tests with and without snorkel and the power was down with the snorkel,.....
If the power is down I would expect the mpg to be down too.
Post #304259 1st Feb 2014 10:14pm
Interlet
As above, a snorkel reduces MPG a bit, but you probably won't notice it very often. 1998 110 300Tdi White Hard Top
Post #304271 1st Feb 2014 11:02pm
cornish rattler
200tdi defender owners is there much difference mpg wise if fitted with a defender 200tdi engine or a disco 200tdi engine, the defender I am going to look at on Friday is a 2.5 td county converted to a defender 200tdi any ideas what mpg I should expect from this Smile Graham
Post #305499 6th Feb 2014 12:46am
RockJaw
United States 2013 Defender 110 Puma 2.2 SW Santorini Black
According to our engineers who have been monitoring our fleet of 2.2s, apparently one of the big culprits is the additional diesel fuel used to clear the DPF through the regeneration cycle. Apparently there is evidence of diesel contamination in the engine oils due to the technology associated with the DPF technology.
Another DPF problem is that traditional engine oils traditionally known to produce superior results in our previous diesel engines are now suddenly showing less desirable performance because of the presence of diesel in the crank oil.
The Engine oils previously specified, including high end Mobil 1 and Amsoil products, are failing at lower mileages. The manufacturer's specified oils are even worse, despite the fact LR filters are in use (and which are the best according to our experience)
Seemingly the first engine oils to fail the manufacturer's oil sheer tests have been those samples sourced from our 2.2 units.
The solution, apparently, is to use a superior diesel (like the BP range already discussed in these blogs) and to install a good filtration system like the German Provent 200.
Seemingly, these rather simple differences has improved diesel fuel consumption in our stock standard 2.2 units by anything between 5-7.5% depending on how the vehicles are deployed.
These 2.2 units achieve over 30 plus MPG quite easily at constant revs and work loads.
These units TEND to have a similar fuel efficiency as our 2.4 units, but we are far from an ideal situation quite just yet.
I am told that what we are waiting for, in order to improve both fuel consumption as well as contamination of engine oils, is new locally developed technology which prevents the injection of fuel during the exhaust/regeneration cycle.
I am hoping Pete from BAS might come up with a solution for my own personal 2.2.
We have certainly seen a whole new series of technological changes in these new 2.2 units, and not all of them are improvements over prior technology. ****CENSORED****
Post #305503 6th Feb 2014 4:08am
Caterham
rockjaw,
how would the dpf enable diesel contamination of the engine oil?
I understand one of the issues of using bio diesel is engine oil contamination however I understand that to be via the piston rings?
you mention the bp ultimate which I believe has no or little bio content?
Post #305516 6th Feb 2014 7:39am
Retroanaconda
Depends on your driving. Mine averages 31 miles per gallon, though it's been a bit down lately for some reason I haven't yet worked out. Doubt there would be a huge difference between the two types of 200Tdi engines.
I can't see the attraction of the "sport" of economy, hypermileing or whatever it's called, I just drive my Defender sensibly and the MPG is what it is. I like to keep track of it though, mostly out of morbid curiosity.
Post #305750 6th Feb 2014 10:12pm
Page 2 of 3 <123>
