Home > Puma (Tdci) > Clutch again!
Page 3 of 3 <123
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
Thumbs Up Thumbs Up Very Happy thank you Bow down NO ROAD..........EXCEPT FOR LANDROVER
Post #303132 29th Jan 2014 3:17pm
Harryb450
the new one
Here's the damage!
the bell housing was full of silver dust which must be metal dust off the springs chaffing on the friction plate centre . 1 main spring out, the others rattle like Censored . the inner and outer spring that had come out were wedged in the cover stopping the clutch from disengaging. the little springs around the centre 1 had a chunk missing and 2 more are broke! the difference now is unbelievable, the slap in the drive has gone completely Thumbs Up Very Happy Very Happy NO ROAD..........EXCEPT FOR LANDROVER
Post #304408 2nd Feb 2014 2:32pm
Dieselhead
Some L/R fixer mates done a 110 pick up before xmas.
The clutch was just like this in your pic. I had a look at the remains in there wk shop Laughing
Got all the bits to do mine now, so just need a day with help from a L/R mate to assist Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #304460 2nd Feb 2014 5:54pm
MK
That looks pretty bad Shocked Puma 110" SW
Post #304481 2nd Feb 2014 6:37pm
Harryb450
Thumbs Up NO ROAD..........EXCEPT FOR LANDROVER
Post #304530 2nd Feb 2014 8:52pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Quick Question;
Is the same size of clutch alignment tool used for both the 2.4 and 2.2?
I can get one from the world favourite auction site, but it just has 2.4 listed?
Post #722137 8th Aug 2018 7:27am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Old thread but I have a suggestion for you. Don't even bother with the EBay Specials. I have one and it was totally useless. You're better off getting an old screwdriver and making it thicker using electrical tape or something to the same effect.
The alignment tools on eBay have a load of slop in them so it becomes guesswork anyway. Save yourself the 15-20 quid! Thumbs Up
If you're totally set on using one, I can send you mine for the postage. (That's how useless it is.)
Post #722157 8th Aug 2018 8:30am
Yannis
Roger, I will give the screw driver method ago.
I am just about to order the clutch fix kit, it’s going in an early 2015 Defender 90.
What is the general opinion of changing the slave cylinder at the same time?
Yan
Post #722200 8th Aug 2018 10:37am
BenB8man
I think most people would suggest that, yes.
On mine, a 2010 with only 40k on the clock I found the slave/release bearing to have considerable play in comparison to the one I was replacing it with.
By the time it's all back together, you'd be swearing at yourself for not getting it done whilst the box is out. Smile
Post #722203 8th Aug 2018 10:52am
Yannis
The clutch fix HD kit has 2 options;
1 including clutch slave and valves etc and 1 without.
As my car is 2015, am I able to get away with just ordering the slave cylinder separate with out the valves etc?
Post #722205 8th Aug 2018 10:57am
BenB8man
As I said, best to just change it. LR took enough shortcuts for you to be doing a clutch change after 3 years.
Post #722213 8th Aug 2018 11:29am
Page 3 of 3 <123
